Help please!
Old May 23, 2017 | 08:27 AM
Anvilsam's Avatar
Question Help please!
Hey all!
This is my first post on here but I have been following for a while.
I have a 2014 Jku with roughly 40k miles on the dash. I had it up on a lift at work because when accelerating from a stop I hear a metal on metal clunk. I have not been able to pin point it. While up on the lift I noticed my front output shaft seal leaking on my t-case. I've done a search and haven't come up with what I'm looking for.
First question- any way those would be under warranty? I have a 4in long arm kit with 35s. I don't want to take it to the dealer and have them charge me if it's not.
Second- if not any guesses on the noise? And anyone have directions/ parts needed for the t-case reseal?
Any help is appreciated!! If there is already a thread on either of these and I missed it please direct me to them.
Old May 24, 2017 | 03:37 PM
tarpon4me's Avatar
JK-Forum Ambassador
You checked your driveshafts? Transmission fluid? Diff fluid?
Old May 25, 2017 | 05:42 AM
resharp001's Avatar
Loved
Community Favorite
Is the clunk something that you hear from stop to acceleration, and from deceleration to stop in both forward or backward motions, I would start by double checking the torque on your control arms. An undertorqued CA bolt can make a "clunk" with changes in direction/motion.
Hard to tell from the description if the noise is related to your TC issue, but only takes a few minutes to eliminate CA's from the mix.
Old May 25, 2017 | 09:04 AM
Rednroll's Avatar
Is the clunk coming from the front or back? If from the back, based upon accelerating, rear sway bar links have known to clunk by hitting the frame if installed incorrectly.
Old May 30, 2017 | 12:19 PM
Anvilsam's Avatar
The noise is definitely coming from the rear and only on acceleration. Although I do hear a intermittent pop now when pulling in and out of driveways. Thanks for the replies. I have checked the trans fluid, drive shaft and sway bar end links. Those all seem good. The CA bolts seem tight but one is further back than the other.. idk if this is normal or not..
Old May 30, 2017 | 12:32 PM
resharp001's Avatar
Loved
Community Favorite
"seems to be good" as in you checked them with a torque wrench? You saying you hear a pop turning in to drive ways now leads me to think it sounds like sway bar links undertorqued. When that body gets even a bit of roll a loose sway bar link will pop.
I can't tell from your response if you actually used a torque wrench or not. I'd note that things will appear tight and "good" but still be under torqued. Some of this stuff even 5-10 lbs under torqued is loose enough to cause a "pop" The rear upper and lower control arms should all be at 125 ft lbs, and the sway bar links should be at 75 ft lbs.
Old May 30, 2017 | 12:58 PM
SPRSLO's Avatar
I agree, if you look at all possible contact points on the frame and suspension and see nowhere that it's rubbing, then I start looking at loose parts. Sway bar, track bar, and control arms. Buy a good toque wrench and get to work learning the settings they all need to be at.
Old May 30, 2017 | 07:34 PM
kmrtnsn's Avatar
Chances are likely that the "clunk" is the exhaust, moving against its stops. Sit in the jeep and have someone grab the COOL tailpipe and shake it back and forth.
