Help - random blue wire
Old Jun 25, 2007 | 04:40 PM
mdlott's Avatar
Question Help - random blue wire
So I started running the coax for my CB antennae and when I popped off the trim piece in the driver's side foot well I noticed that there was a blue wire just hanging there. The end was taped with electrical tape and I can't figure out where it goes. Does anyone know what it is for and if it should be connected to something?
Here's the photo (assuming I'm posting it right):
Thanks!
Old Jun 25, 2007 | 06:06 PM
HookNLadder's Avatar
Interesting -- I have a similar situation under the hood but I think thats from where they installed the trailer hitch wiring.
Did you hook a test light to it and see if/when it gets power??
Old Jun 25, 2007 | 08:26 PM
1BADJK's Avatar
That is your trailer brake activation wire..
Old Jun 26, 2007 | 03:35 AM
mdlott's Avatar
So if I have the factory tow package, shouldn't that be hooked up somewhere. I did hook a test light up to it, but it wasn't getting any power (even with the ignition on).
Mike
Old Jun 26, 2007 | 05:09 AM
1BADJK's Avatar
It hooks up to trailer brake controller.. As of now its just a dead wire.. The trailer brake controller supplys voltage out and thats the wire that goes back to the trailer brakes.. It was nice of them to run it into the cab for you.. I would just roll it up and zip tie it up under the dash more out of the way..
Old Jun 26, 2007 | 05:22 AM
mdlott's Avatar
Will do - thanks for the info.
Old Jun 26, 2007 | 01:39 PM
101gargoyles's Avatar
Former Member
I've never had a trailer with electric brakes so maybe someone can enlighten me. If the blue wire goes to the output of the controller,is the other end one of the four pins on the trailer light connector plug at the rear? I thought those were all for lighting.
I'm still debating whether to go with electric or hydraulic surge brakes to retrofit on my jetboat trailer.
Old Jun 26, 2007 | 01:47 PM
1BADJK's Avatar
If you only have the 4-pin on the back then mostlikely you don't have the blue wire...
It is not connected to the 4-pin...
Old Jun 26, 2007 | 01:58 PM
Former Member
In that case Is the opposite end of the blue wire tied away in the back of the Wrangler somewhere waiting to be pulled out by the hitch area?
I'm just wondering if the end behind the footwell panel might be the input signal to a brake controller.
I have the O.E. tow package which only has the flat 4 pin plug.
Old Jun 26, 2007 | 03:41 PM
1BADJK's Avatar
Most likely its behind the rear drivers side tail light..
