View Poll Results: How did/will you break-in your new JK's engine?
1: "RTFM": Soft but safe; aka "the engineers know best."
26.83%
2: "DILYSI": Drove it like I stole it - extreme break-in style.
12.20%
3: "Felt it Out": Somewhere between 1 and 2, not TOO extreme, not too wimpy.
54.47%
4: "The Scientist": I followed a strictly-controlled routine (explain).
3.25%
5: Other (explain): None of the above describe my method. :question:
3.25%
Voters: 123. You may not vote on this poll
Help settle an argument re: Engine Break-In
Old Mar 16, 2007 | 01:10 PM
  #21
Dr.McNinja's Avatar
http://www.mototuneusa.com/break_in_secrets.htm
Old Mar 16, 2007 | 01:18 PM
  #22
Dr.McNinja's Avatar
Also (From WRX forums)
Break-in how to
There are generally two points of view:
a. The engineers who designed it know best -- RTFM
b. Drive it like you stole it
A new engine (or any other mechanical device) is a little like a new pair of shoes. Everyone knows from experience what would happen if you put on a brand new pair of hiking boots and went for a long run. Big time blisters on your feet. In a mechanical device the same sort of high pressure injury occurs, but an engine or a gear does not blister, and cannot heal. You either break it in correctly or you damage it permanently.
The break in process is actually a carefully controlled form of wear, like the new shoes, it is a chance for the mating parts to "adjust to each other". In a shoe and your foot, most of the adjustment takes place as the shoe leather stretches and softens from repeated flexing. To a lesser extent your feet will form a callous to protect any area where a pressure point persists.
No engine, bearing, gear or other mechanical device is perfect. If you look at a machined surface under magnification a piece of steel that looks to be smooth and polished is actually as rough as sand paper, only the peaks and valleys are on a very small level. When a machinist turns a shaft to a certain size, he is actually working to an acceptable error called tolerance. The crank shaft main journal may be specified to be 2.5 inches + or - 0.0002 inches and a surface roughness of maybe 50 millionths of an inch.
The bearing clearance is the space between the bearing journal and the bearing shell surface where the oil film is supposed to exist. Lets suppose the clearance on this crankshaft is supposed to be 5/10000 of an inch to 7/10000 of an inch. Now suppose you take a bearing that is on the small side with a nominal clearance of 5 ten thousandths and put it on a journal that is at the large limit of 2.5002 inches. You have an actual clearance between those two high points of only 3 ten thousandths of an inch. On another journal in the same engine you might have a large bearing that has a nominal clearance of 7 ten thousands of an inch and a small journal that is only 2.4998 inches in diameter. On this bearing the actual clearance would be 9 ten thousands of an inch. Needless to say the bearing that has a true running clearance of 3 ten thousandths of an inch is going to have much less room to expand if it gets hot than the looser bearing journal that is at 3x the clearance.
In real life the crank shaft journal actually moves around inside the bearing. On average the bearing maintains a thin oil film between the moving parts but from time to time, under high loads or just due to random vibrations and variations in oil pressure and such, the bearing and journal will move into very close contact. Over time this will "burnish" the high spots down so the average surface is much smoother than it was when it came out of the factory. Over time the appearance of the surface roughness will begin to look like a lot of table top mountains, as the upper most points on the the surface get either worn or beaten down by millions upon millions of small impacts.
The break in process is intended to facilitate this "wearing in" process with out giving your engine the mechanical equivalent of a blister.
What is a mechanical blister ?? on a fly wheel or a brake disk it is a premanent hard spot created by overheating a small high spot which is rapidly cooled by the metal surrounding it. This portion of the flywheel or brake disk will never wear at the same rate as the rest of the disk and will cause chatter and uneven friction for the life of the part. On a bearing it can be a hot spot on the surface that either hardens or softens the bearing surface or destroys the thin wear resistant coating put on by some manufactures. On a gear tooth it will be change in the hardness of the surface of the gear tooth that will make it wear or break under load. It could also lead to micro-cracking due to the rapid heating which will permanently weaken the gear. On a piston ring it can be scratching or scoring of the cylinder wall so the engine will always use oil to a softening of the piston rings due to over heating that results in poor ring seal and low compression and oil consumption.
How do you allow controlled wear? You have to create a situation where you have sufficient load to create the brief periods of close contact required, without over heating or damaging the bearing surfaces.
The RTFM approach to auto break-in will give you a reliable car that does not require any warrantee work due to problems you created by mistreating the car in its first few miles of use. IT DOES NOT necessarily give you the best running car, or the most horsepower from your engine.
The drive it like you stole it approach will MOST of the time, give you a powerful engine, but may lead to various trips to the dealer for things you pushed too hard too soon during the first few miles of driving.
The best break in approach is about half way between these two extremes. The cam shaft and the cam followers are among the most heavily loaded parts on an engine, and need special care during the first hour or so of engine operation to avoid permanent damage. The bearings through out the engine and the gears in the transmission and differentials also need a pattern of alternating load and time to cool starting at low intensity and gradually increasing stress, to avoid permanent changes in gear hardness. The piston rings require brief periods of heavy load (hard acceleration), to seat the rings, followed by time to cool. The brake pads and brake disks as well as the flywheel and clutch need a progressive pattern of bedding in for the friction material and friction surface to get properly conditioned to avoid permanent damage due to over heating or poor performance due to improper bedding.
Most people think of the break-in process as applying to the engine, but it actually applies to the entire car and all its systems.
So what do I recommend for a break-in procedure?
First, cater to the cam shaft and the bearings, piston rings and cylinder walls in the engine. Start the car and hold the engine at a slightly fast idle (about 1500 -2000 rpm), let the engine run at this fast idle with slight variations is speed for about 30 minutes or until the engine is at full operating temperature for a minimum of 10 minutes.
Second, begin the bedding in process for the clutch, brakes, and the break-in process for the gears and piston rings/cylinder walls.
Take the car for a short drive (drive it home). Make a point to not slip the clutch too much, or ride the brakes too much, accelerate briskly up to the recommended rpm limit the manufacture gives in the break in guidelines, but be sure to give plenty of time between the periods of brisk acceleration for the engine to cool any hot spots. After you have several minutes of driving on the car, in a safe location, make some moderately hard stops to begin the bedding process on the brakes, but space them well apart so you never smell hot brakes. By now you should have a feel for the clutch, make a couple moderately hard accelerations which load the clutch a bit, again with plenty of time to cool. By now you should be home. Park the car someplace where you will be able to see any drips, and let it cool completely.
After the car has cooled down, check all your fluids to be sure all your levels are good. Look under the car and check for drips.
Take the time to give the car a good visual inspection. Think like a pilot giving a plane a pre-flight. Grab stuff and try to shake it, check tire pressures, oil levels, get out the owners manual and learn where the transmission fill is, where the brake master cylinder is, where the fuse boxes are, how to turn on the 4 way flashers etc.
Now your ready for phase 2. Take the car for another drive, where you have a lot of stop and go driving. Find a residential neighborhood that has lots of stop signs and learn the feel of the clutch. When conditions are safe, make a few brisk accelerations to seat the rings and bed in the clutch, then pull your speed down briskly (about 50% effort) with the brakes to help bed in the brake pads. Again be sure to give the car plenty of time to cool with easy "grandma driving" between these bursts. (be careful your brakes will not grab at full strength until the bedding process is complete - don't put your self in an emergency must stop situation !!)
Find a low traffic highway and make a max effort acceleration up the on ramp to highway speed, revving the engine to the max rpm listed in the manufactures guide lines in each gear (lets not go 140 mph here guys :blink: just 1-4 th gear ). cruise for a mile or two, to let everything cool and then find a safe place to make a 75% effort stop or two. Do this several times then take it home and let the car cool over night. Follow this pattern for a couple days, gradually increasing the level of effort on brakes, clutch and acceleration until you have about 200-300 miles on the car. At this point you should be able to make max effort stops and accelerations, but still limit your engine rpm to the max rpm recommendation by the manufacture.
From this point on, drive the car hard (safely!!) and every 100 miles or so, raise your engine rpm limit by 100-200 rpm. By this time you can make long highway trips with no problem, just avoid running on cruise control for extended periods of time. If you do use cruise control, periodically vary both speed setting and/or alternate between 4 th and 5th gear.
Switch to a quality synthetic oil on your first oil change, and by the time your at about 3000 miles you should have finished all the break in that requires special precautions. The engine will continue to gain power for the first 5 - 10 thousand miles as it slowly loosens up.
Old Mar 16, 2007 | 02:10 PM
  #23
MJS_Jeep_888's Avatar
A lot of the theory of the above post sounds good, but let me caution you - I just traded in my WRX for my JK... and (like it needs to be said!) they are VERRRY different vehicles. A 2.0L turbocharged engine is not even close to the same as our 3.8L NA engine... also, for the most part, you can totally disregard the parts of the above post regarding seatin g your brakes and "loosening up the engine" for the first 5 - 10K miles.
My WRX engine definitely DID grow in power as the miles piled on, but it was a small, high-compression, tight-tolerance engine (compared to the 3.8L). But I really doubt that you're doing to see a continual growth in output from the 3.8 beyond the first few thousand miles... if anything, I would expect the fuel economy to increase as the 3.8 wears-in. Anyhow, there's a lot of good theory in that post - just trying to say that a lot of it doesn't fit real well with a Jeep (unless you're going to try to autocross it or something ).
I DO agree with the 1/2 "drive it like you stole it" 1/2 "baby it" approach... seems to have worked very well with my JK thus far (700 increasingly fun miles and counting).
Old Mar 16, 2007 | 04:48 PM
  #24
clubber's Avatar
Again.....................read your owner's manual..........
Old Mar 16, 2007 | 09:27 PM
  #25
You must've missed it Clubber - I posted the section from the owner's manual, but people still decided to offer up their own .02 (as is their right, of course).
Old Mar 17, 2007 | 05:03 AM
  #26
clubber's Avatar
NO.....................I just like to keep saying that , and from the looks of things it won't be the last......
Old Mar 17, 2007 | 07:24 AM
  #27
pulman01's Avatar
To eveyone posting their opinions on engine break-in.
I appreciate all the input. There are alot of us mechanically impotent jeepers out here (this is my second and learn something new all the time). I have searched and read, and searched and read, so all of this does help. So even if everybody doesn't agree, keep on posting because it sheds light for some of us out here.
Old Mar 17, 2007 | 11:40 AM
  #28
Dr.McNinja's Avatar
FWIW, the owner's manual is not very in depth on this subject. Yeah, their recommendations won't break it, but at the same time, neither will what most of us are recommending. Tell you what, you do what you want with your money, and I'll do what I want with mine.
I'll bet you aren't telling people that they shouldn't put non-MOPAR items on their Jeeps (which the manual says to do), so why are you picking this subject as an example of the infallibility of the manual?
Old Mar 17, 2007 | 11:52 AM
  #29
Default Correction needed...
I just want to chime in here... we've all posted a lot of good, useful information, and while there are a few points of contention on certain specifics, I think we all seem to agree more or less on the basics. However, we're all wasting our time. The title of this thread is "How to break a new motor." We've been posting information for how NOT to break a new motor!
So, if you're interested in BREAKING a new motor, as the thread is titled, try this method - it'll work for sure.
1) Drain out all of your engine oil, immediately upon taking delivery from the dealership. Ditto for the coolant - this is critical to success.
2) Regardless of transmission type, put your transmission in Neutral. Rev the engine for a minimum of 10 minutes, and then, at full throttle, perform a "Neutral Drop," slamming the tranny down into 1st while giving it as much gas as possible.
3) After steps 1 and 2, above, continue to drive around ONLY in 1st gear - this is regardless of transmission type. Never shift, and see how high you can get your speed up in 1st... your goal here is to keep the tachometer pinned at red line for as long as possible.
4) Drive until your engine ceases to function (the ride home may not be enough - you may have to take 'er out on the highway for an extended run).
5) Success - you have now successfully "broken" your new engine. :toung:
Old Mar 17, 2007 | 11:56 AM
  #30
The manual is far from infallible, and I didn't read his post to mean that it was... I took it to mean that someone that doesn't know how to treat an engine should go by the manufacturer's recommendations... after all, THEY'RE the ones that built and tested the engine for durability, etc. Will following the manual result in "optimum break-in" where power and output are concerned? Probably not. Will it do any harm to the engine? DEFINITELY not.
