HELP! Sheared off lugnut
Old Apr 23, 2016 | 11:03 AM
2012-JKU-Brad's Avatar
Default HELP! Sheared off lugnut
I was tightening a lug nut and it sheared off right at the base. I took it to a couple places and they said they couldn't get it off. Does anyone have any suggestions?
Old Apr 23, 2016 | 11:08 AM
YYJ-JK's Avatar
Try welding a socket to it.
Old Apr 23, 2016 | 11:13 AM
I was going to try that but I don't have access to a welding machine
Old Apr 23, 2016 | 11:25 AM
YYJ-JK's Avatar
You could also try hammering a socket on over top of it...not much left for it to bite on though. Find a socket that is just a bit to small and hammer it on...just be careful you don't damage the rim
Old Apr 23, 2016 | 11:32 AM
I will try that but there isn't much to grab on to. I don't think I will be able to save the stud. I'm thinking about trying to drill the stud out.
Old Apr 23, 2016 | 11:33 AM
Mark Doiron's Avatar
Since you were willing to take it to "a couple places", why not take it to a professional welder? Not an auto mechanic who can weld, but a professional welder who can take care of that without causing further damage?
Old Apr 23, 2016 | 11:34 AM
YYJ-JK's Avatar
Might be able to grind the back of the stud off and hammer it through
Old Apr 23, 2016 | 11:36 AM
karls10jk's Avatar
Worst case scenario- I had a friend take a hole saw to one in a similar situation. He was able to fix it after the wheel was removed. It wasn't a pretty fix though and obviously the wheel gets discarded unless you have someone weld a new center into it.
Old Apr 23, 2016 | 12:21 PM
DJ1's Avatar
DJ1
Former Member
^ this right here...
Old Apr 23, 2016 | 12:35 PM
Kellen's Avatar
You could try drilling out the lug then replacing it.
