HELP!! - Tire Flash Info Needed
My dealer says they are unable to flash the computer for 07 JKs (I have changed my tire size to 265/75 16 from the stock 225/75 16). Does anyone know of something (service notice?) I can point the dealer to?
Thanks,
Joe
Thanks,
Joe
If they tell you they can't do this, find a new dealership
-E
So you are saying they can flash it? When I talked to them, we did not talk tire size. They just said that starting with the 06 model wrangler they could no longer update the speedometer for larger tires. My understanding from reading the forums is that they can update the computer for up to around 32 inch tires.
If this is the case, is anyone aware of some kind of documentation I can point them towards?
Thanks,
Joe
Thanks,
Joe
Thanks,
Joe
Thanks,
Joe
-E
Has anyone bought one of these yet?
Superlift TruSpeed Speedometer Calibrator
Main Features:
Corrects speedometer / odometer readings, and the speed signal sent to the engine, Powertrain, and anti-lock brake control modules. Besides the obvious, these modules affect fuel delivery, engine timing, and automatic transmission shift points.
Eliminates speed signal related reductions in engine performance and fuel economy, as well as related changes in exhaust emissions
Infinite adjustability provides precise speed signal calibration within 1%
Two settings allow off-roaders that seasonally run different height tires to correct their speed signal by flipping a switch
Simple four-wire hookup
Includes complete instructions and adjustment charts
Can be recalibrated infinitely for future tire size or gear ratio changes
Works on most vehicles equipped with an electronic speedometer
It runs $185...I'd hate to spend cash on junk...but it would be nice to have my speedometer be correct.
I asked a dealer to change the settings on my Jeep to the 32" tire size--they didn't want to do it (not that they couldn't), so I didn't push the issue at that time. I'm running 285/70R16 BFG AT K/Os on stock rims. The diameter lists as 31.7--the 32" setting would get me really close; like within about a percent.
Has anyone bought one of these Superlift TruSpeed Speedometer Calibrators?
I found the link: ntwonline.com/acb/showdetl.cfm?&DID=48&Product_ID=1973&CATID=15 on a Jeep Club page.
Main Features:
Last edited by HappyCurmudgeon; May 21, 2007 at 04:48 AM. Reason: Please refrain from posting direct links to non sponsoring vendors.
With the orig 225's, speedo was dead nuts as per GPS. With 265x75xr16 BFG AT's, it was ~8% off(speedo reads 8% slower than GPS), which happens to be the diff in tire circumference. For $50, had the dealer "flash" my speedo for the new tire size. They must have flashed it for something like a 31" tire, because now it is still ~2% off(reads 2% slower than GPS).
Main Features:
Main Features:
To my knowledge those will not work on the '07's. (I cannot 100% verify that, it is just what i was told by a local 4x4 shop that supposedly looked into it)
