Help with Torque Spec
Does anyone know what the torque spec is for the brake lines to the caliper? I snugged them up and still had leaks. Then snugged some more and twisted the bolt! Do the brass washers need to be replaced? They don't seem to be working too well. Thanks!
TORQUE DESCRIPTION
N·m Ft. Lbs. In. Lbs. Brake Booster Mounting Nuts 25 18 — Master Cylinder Mounting Nuts 17 13 151 Booster Mounting Plate 18 — 159 Master Cylinder Brake Lines 19 14 168 Front Caliper Adapter Mounting Bolts 35 26 — Rear Caliper Adapter Mounting Bolts 35 26 220 Front Caliper Brake Hose Banjo Bolt 31 23 — Rear Caliper Brake Hose Banjo Bolt 31 23 — Front Caliper adapter 163 120 — Rear Caliper adapter 75 55 — Parking Brake Lever Bracket Bolts 12 9 — |
Yes you have to replace the crush washers! They crush when you tighten them. I had to go pretty dang tight to get the new ones to both crush (one on each end of the banjo bolt). Well over the above spec'd 23 ft/lbs. I didnt feel the banjo bolt twist at all though. It held up to a day on the trail with a lot of braking....since I have an auto. and no real low range. :) I drove it 600 miles home too and feel good about the brakeline job. The only complaint I had was that the lines I got didnt come with the retainer clips for the rear lines...I had to rig something up. No biggie but those are pretty important IMHO. :)
The fitting on the hard line on the pass. rear was stubborn too....always feel like Im going to snap those things. :) |
Originally Posted by Audiophiliac
(Post 525293)
Thanks all for the info!! Awesome forum! I will be picking up some new washers tomorrow.
| All times are GMT -8. The time now is 05:21 AM. |
© 2026 MH Sub I, LLC dba Internet Brands
