Sponsored by:
Sponsored by: DashLynx
Hi lift jack.
Old 11-29-2016, 07:09 PM
WEB4BYN's Avatar
I've used mine once. But I needed two. In the rocks. It would suck if we didn't have them. Broke both my front and rear axel.
Old 12-06-2016, 06:10 PM
idiot magnet's Avatar
you mean the "Widow Maker"?
Very dangerous if you are not experienced with it. Mine lives in my storage unit and doesn't get used.
Old 12-11-2016, 10:52 AM
SlendermanJK's Avatar
I had floor jack lent out to someone when I had to do full brakes I used my Hi-Lift it's not the safest option but works when needed defiantly would not of used without jack stands it swayed from the wind while lifting
Old 12-11-2016, 12:42 PM
FFEMT510's Avatar
I've used mine a few times in the year that I've had it. Had to flip my swaybar back after snapping end links. I used it to put some rocks under my tires when I got high grounded in about 14" of snow. And I used it to winch my wife suv out of the ditch in a different snow storm.
I've since bought a winch which would have helped in two of those three situations, but as you can see it will still have its place.
Old 12-11-2016, 06:40 PM
Chuck-The-Ripper's Avatar
Works pretty well checking clearances as well
Old 12-12-2016, 11:31 AM
Vintage's Avatar
Sorry to get off topic, but I thought to check clearance you need to remove the coils, as stuff gets torn off during dynamic maneuvers (e.g. falling off a rock) instead of static ones like you've pictured since the force of the former will be a lot greater and compress the coils a lot more. So bump stops will be what the weight rests on rather than coils to check clearances.
Old 12-12-2016, 01:26 PM
DJ1
Former Member
DJ1's Avatar
I've got the First Responder version but painted the yellow bar gloss black. I've only used it a handful of times for jacking the jeep up but it's primary purpose is for widening/extraction/jaws of life.
The modified/upgraded base that comes with it makes it more suitable for SHTF scenarios. Better to have one and not need it, then....
Name:	Screen Shot 2016-12-12 at 2.12.00 PM.png
Name:	Screen Shot 2016-12-12 at 2.23.06 PM.png
Old 12-12-2016, 07:51 PM
I didn't take the time to comprehend exactly what you're saying... but from the bit I gathered...
Do you Offroad without your coils? Because I don't. The only thing removing coils does is make it easier to cycle the suspension without having the coils raising the jeep. In this photo I was ensuring my shocks were not bottoming out before my coils were fully compressed.
Old 12-13-2016, 11:00 PM
Vintage's Avatar
If you were coming down hard off a ledge, wouldn't your coils compress even more on landing than what you've pictured?
Old 12-14-2016, 05:42 PM
KG4NEL's Avatar
I'm interested to see how the new Hi-Lift roll bar mount will fit in the 4-doors. I don't carry one, but I'd be more inclined to if I could carry it inside without taking up floor space.
I do have a surplus van bottle jack, but I could foresee getting into a spot where lifting under the axle isn't really what I need, or setting the jack would involve going for a swim. I have Hi-Lift points on both the front and rear bumpers anyway, so...
Quick Reply: Hi lift jack.
