High pitched whistling when accelerating
Old Jan 5, 2011 | 01:12 PM
  #21
DucMan's Avatar
Originally Posted by h1ker
Youve probably already checked this but I had a whistle like that and it was a leaf on the top side of my air filter in the intake tube
My first thought
Old Jan 5, 2011 | 03:53 PM
  #22
burbingus's Avatar
I'm going to try to get this sorted out tomorrow evening.
Originally Posted by juno
Had a similar issue on my 330i a couple years ago. High pitch whistle that was seemingly dependent on throttle position. Ended up being a crack in the intake tube just before the TB. I know you've already checked it but it sounds like you could have a very slight crack at the bend.
I'll definitely go over the intake closely to try and find any cracks or other damage.
Originally Posted by AMCJeff
My jeep made a whistle when I smashed my exhaust. The engine would wine when driveing on freeway around 60mph. Probably not your issue but a quick look wouldn't hurt.
Good to know; I'll check the exhaust out as well.
Originally Posted by DucMan
My first thought
Checked the airbox and intake for debris and didn't see any, but I'll take a closer look tomorrow.
Micah
Old Jan 7, 2011 | 05:44 AM
  #23
burbingus's Avatar
So last night I replaced the serpentine belt and engine idle pulley. The idle pulley had some debris wrapped around it. I also double checked the intake hose for any cracks and cleaned all the mating surfaces.
Unfortunately, the sound was still there this morning. Tomorrow I'll check all the vacuum lines to make sure they're ok.
Micah
Old Jan 7, 2011 | 06:05 AM
  #24
mpkelley20's Avatar
Micah
I doubt this is the case, but as I mentioned with mine, it was the tensioner pulley that was causing my noise, not the idle pulley. they are the exact same pulley so you could probably just take your old idle pulley and subsitutie it for the tensioner to see if that helps...but it sounds like you may have a different problem
Old Jan 7, 2011 | 10:47 AM
  #25
burbingus's Avatar
Ahh, I meant the tensioner pulley in my last post; that was the one that I replaced.
Micah
Old Apr 8, 2011 | 12:35 PM
  #26
Stkman252's Avatar
I believe that it is the air going accross the throttle plate under load. I have this noise. I put a afe cai and the noise was worse. I then put a new throttle body on and i couldn't stand it, was worse than ever. Took off the cai and now it is better but stll there.
Old Apr 8, 2011 | 01:54 PM
  #27
Yamaha90's Avatar
Same Same Same... had a CAI on and the whistle drove me crazy and i put the stock box back on and there is a very slight whistle at times but otherwise it's gone.
Old May 13, 2011 | 12:21 AM
  #28
tomslik's Avatar
Forum Media Contributor
So, any new news on this mysterious whistle noise? I landed here after a search, since I have a very similar noise that I've been chasing, and I sure was hoping to see a solution! I do have the Banks Ram-Air CAI, Magnaflow exhaust, and my noise seems to be intake related too, and I'd really like to make it go away. Especially with the roof down and doors off, and the fact I have no inner-fender liners you can really hear every odd noise under the hood...
Old May 27, 2011 | 04:47 AM
  #29
NC9287JK's Avatar
I have to beleive this is related to the throttle body. I have the same issue. I only noticed it after I pulled and cleaned the throttle body last week. Maybe it was there before, but wasn't as noticable. I too have a CAI but have had it on for 6 months now. I don't see any damage to the TB gasket, but it looks like I will be replacing it as my next step. Has anyone found the ultimate fix for this yet?
Old May 29, 2011 | 11:56 AM
  #30
jcrowell's Avatar
same whistle/ whine here post TB cleaning. 07 Jeep is stock. 57k miles. I'm going to continue working on it and post if solution is to be found. 1900-2100 RPM only under load/ when moving- J
