How can I turn off the auto lock feature??
there's already a number of threads on this, but:
get in and close the doors. turn the ignition on to the last point just before you would start the engine. turn it back off. do this 4 more times to make a total of 5 times. on the 5th time, it should be left at the ON position. within a few seconds, push UP on the driver's side power lock switch twice. this will disable auto locks.
personally, i left the auto locks enabled. instead, i only pushed up on the power lock switch once when doing this procedure. this enables all doors to unlock when i open (unlock) the driver's side door. i figured the auto locks will probably be a good thing for when we've got a kid.
Thanks for the info..
If I had children I would leave them enabled.But I use my jeep for work(construction)and everytime I got to the back to open the gate and get a tool out it is locked and I have to go around to the front door and unlock it
Very small thing,but annoying..
Thanks again.
Thanks again.
Thanks again.
Thanks again.
glad i could help
JeepSWAG
Sponsoring Manufacturer
well, the way i set it up (1 up instead of 2), when i open the driver door, all the doors unlock anyways. so that would solve your problem as well as leaving the auto locks on. but whatever suits you best. also, if you read the manual, there's a sequence you can do with the key fob to set it so that hitting the unlock button on the key fob once unlocks all doors instead of having to do it twice.
glad i could help
glad i could help
Good recommendation.
I have a three year old, and I found that the "1 up" setting is the best solution for families. With the default auto-lock setting, you have to manually unlock the doors, every time you go to get your child out of their car seat. With the "1 up" setting, the doors unlock as soon as I get out of the car. Funny story; my wife won't let me drive with my son, sans doors. If you see a silver Jk driving around SoCal with the front doors off, and the back doors on,... that's me. Here's my boy and his ride hangin out on our first drive off-road.
i _have_ read about other people having to do this 6-8 times before it worked for them. i'd suggest just trying all the steps over from the start. it should work just fine for you if you follow the steps. i got it on the 1st try - i'll add that i was fairly quick about the on-off-on-etc. maybe even have a friend or spouse read the directions and let them do it under your supervision. perhaps you're missing or botching a step and not realizing it.
is there a list somehwere that has all these neat things writen down? I want to disable the headlights from coming on when you unlock the car. Also that nasty door chime needs to go so i can play my jams with the door open.
as for music with the door open....just put the windows down and drop the top, that's why you got a jeep!
