How can you tell if ball joints are bad?
Old Aug 31, 2010 | 04:37 AM
RyanBlack321's Avatar
Default How can you tell if ball joints are bad?
How do you inspect ball joints? what will you see or feel if they are bad other than some steering wobble?
thanks
Old Aug 31, 2010 | 04:41 AM
Bacon's Avatar
jack up your front axle taking the weight off your tire. grab the tire at the top and bottom, and push it in and out. it there is any movement in or out top or bottom, the ball joint is bad.
Old Aug 31, 2010 | 04:53 AM
rinkishJK's Avatar
Default Re: How can you tell if ball joints are bad?
U also while jacked up take a pry bar or some sort of bar and stick it under the tire and pull up. Mine were bad this way and were tight the way previous poster said. U check that way also.
Sent from my Droid
Old Aug 31, 2010 | 05:03 AM
ronjenx's Avatar
Here is the whole story:
Radial (side-to-side) movement in the upper ball joint should not exceed 0.060" (1.5mm).
Axial (up and down) movement in the lower ball joint should not exceed 0.050" (1.25mm).
This is how to check:
A dial indicator is the best instrument to measure ball joint play.
Jack the front tire off the ground.
Place a jack stand under the axle next to the jack.
Lower to put some weight on the jack stand.
Place a long pry bar under the tire.
Have someone pry the tire up and down while you watch the lower ball joint for up and down play.
Have someone grab the tire at top and bottom to wiggle the top in and out while you watch the upper joint for side play.
Even if the upper joint checks good, change both if the lower checks bad.
Old Aug 31, 2010 | 08:13 AM
98jeepboy's Avatar
Haha, i have never seen a shop use a dial gauge. I will say it like they told us in class. If it moves enough to be seen. Then replace it. It is better to replace in pairs not just the single one. The reason being you have just beat and togged on both removeing the hub. An what i mean being seen is that you can visual see play. 1.5mm is about the thickness of your key and you should not be able to see that.
Old Aug 31, 2010 | 10:09 AM
ronjenx's Avatar
1.5 mm (0.059") is quite a bit.
My lowers are at 0.51mm (0.020") and the axial movement is plainly visible.
Old Sep 2, 2010 | 12:34 PM
Bacon's Avatar
Sent from my Droid
yeah, what he said. if it's bad enuf to move by hand like i said, it's really bad. a pry bar would give you a more exact guesstimation. i just don't have a long pry bar
