Sponsored by:
Sponsored by: DashLynx
How do I identify "bad" engines in oil consuming 07-08 JK jeeps?
Old 09-08-2011, 06:56 PM
Smizar's Avatar
Originally Posted by Ryan0260
Not necessarily but it does seem to be a symptom of the bad motors. Mine is doing both also and started my consumption test last month. My pinging seems worse when it is hot out and more so when the oil is getting low. I am anxious to see how much it has lost next time
I've been a jeep fan for many years although this is the first wrangler I've owned, I've always had CJs. I got this 08 jk new and we have issues with the top leaking, the engine burns oil,the trans pops out if gear,the rear end is worn out and now the cruise just quit working, not to mention the seat belts fraying, and it hasn't even hit 70,000 on the clock yet. I think I'll stick to my CJs..
Old 09-08-2011, 07:01 PM
EzK
EzK's Avatar
If it makes you feel any better my '08 JK burns 1qt or less per 5,000 miles.
Old 09-08-2011, 07:34 PM
bkjeep's Avatar
With all the craziness am I nuts to say mine doesnt burn any oil?? None that I notice anyway.
Old 09-08-2011, 07:55 PM
jktoy's Avatar
Mine is fine. It burns about a half a quart every couple thousand miles. And it's an 08 with 84000 miles. The only problem I have is with it jumping out of first.
Old 09-09-2011, 02:09 AM
red97xj's Avatar
What year is yours?
Old 09-09-2011, 03:00 AM
red97xj's Avatar
Originally Posted by duneslider
Mine was a USA engine and has problems so the issues can't just be blamed on the Mexico engines.
What problems do you have? What do your plugs look like? Picture of plugs?
I won't have a chance to do an oil consumption test, but I can check oil level and pull a plug.
Thanks for your help!
Old 09-09-2011, 04:12 AM
JKlad's Avatar
They'll be black and sooty looking and probably slick with oil, and if enough oil is entering the combustion chamber they may have peeling black carbon deposits on the electrodes. Healthy plugs look dry and are just dusted with a greyish brown coating (not to be confused with plugs that are burnt white or very light grey which is a sign of a motor running too lean & hot).
Old 09-09-2011, 04:38 AM
Yankee's Avatar
Used to be you might tell by running a finger around the exhaust pipe outlet if it burned oil bad. That may no longer be true with cat converters though, not sure.
If they are smart enough to fill the oil and put fresh plugs in, might be hard to tell.
Old 09-09-2011, 05:06 AM
Ryan0260's Avatar
What year is yours?
It's an 07. By the way the tailpipe is clean so apparently not all oil consuming motors have soot buildup in the pipe
Old 09-09-2011, 05:25 AM
Yankee's Avatar
Ya, thinking the cats might eat up the oil, until they fail.
Quick Reply: How do I identify "bad" engines in oil consuming 07-08 JK jeeps?
