How do I know my stock axle ratio?
No clue how to calculate the ratio like that but I would ask what did you order?
Looking at the sheet that came with my X, it comes with a 3.21 standard but I ordered the Tow Group package which inlcuded a 3.73.
best thing to do is check the window sticker. Gear ratio is correct in Seir post. Make sure the window sticker states the tow group package then you know you have the 3.73 gears. If it is a dealer add on (tow hitch) I doubt they changed the gears.
Write down your VIN number and go down to or call you local Jeep dealer's service department and ask them to run a function 14 with list of vehicle options. This will tell you everything you will ever want to know about your jeep.
I bought my car from Dubai, vehicle specs in the showroom says 3.21 sales man says 3.73 then checked with service center & said its 4.10 !! Thats why I got so confused !! Any 1 with a manual Rubicon & stock tires can tell me whats the rpm @ 60 mph in 5th gear?
According to the gear calculator I use, with a six speed and the stock 255/75R17 tires the RPMs are as follows for 60 mph in 5th gear
3.21 = 2,019 rpm
3.73 = 2,346 rpm
4.10 = 2,578 rpm
3.21 = 2,019 rpm
3.73 = 2,346 rpm
4.10 = 2,578 rpm
