How do I reset my oil change light?
Darn thing keeps beeping when I start the Jeep, but I changed the oil already. Also are there any lube spots I need to hit under the Jeep when I change the oil? |
With the key on and engine off, depress the skinny pedal 3x.
That should take care of it... |
Read page 209 of your manual
To reset the oil change indicator system (after
performing the scheduled maintenance), refer to the following procedure: 1. Turn the ignition switch to the ON position (Do not start the engine). 2. Fully depress the accelerator pedal slowly three times within 10 seconds. 3. Turn the ignition switch to the OFF/LOCK position. NOTE: If the indicator message illuminates when you start the vehicle, the oil change indicator system did not reset. If necessary repeat this procedure. |
Originally Posted by chrisfetz
(Post 1533763)
Kind of a Hijack but, do all the JK's have the oil change reminder? I've put on more than 3000 miles since my last change and didn't reset anything at the time. Is it a timer or an actual oil analyzer gizmo?
Originally Posted by Bennyhana
(Post 1534047)
Originally Posted by musicman
(Post 1534180)
It is an actual analyzer measuring several diferent functions in the vehicle. Gotta love computers. :thumbsup:
Originally Posted by Adam3612
(Post 1534781)
Are you sure? I changed my oil at the first of October with just under 26 000 kilometres on it reset indicator when I was done, now have just over 30 000 and it came on last night. The oil appears to be fine, which it should be considering its Mobil 1 synthetic and its only been in there not quite 4 months. I think these things are kinda screwy if you ask me because this isnt the first time the indicator has come on way too early. According to the manual we can go up to 10 000 km's er 6 months between oil changes, (not a freakin' chance in hell I would try to pull that off).
If you have lots of cold starts, drive short trips, spend a lot of time in stop/go traffic, eat a lot of road dust, or do not spend sufficient time at operating temperature, then you are running "severe" conditions. 4000km (2500 miles) seems to be a common number for many folks. I change at 5,000 - 5,500 miles (or 6 months but that never happens!) and only got the chime once. Mobil 1 oil and filter. if the synthetic is emptying your wallet to quickly, just use a good brand of dino. But personally, I would make the change when alerted. |
I don't have a hoe to reset my light:rotflmao2:
Originally Posted by EagleArmsHBAR
(Post 1533757)
i usually just tell my hoe to get back in the kitchen and make me a sandwich
