Originally Posted by Jiblet
(Post 1535009)
The jeep does not actually analyze the oil itself. But it does run an algorithm that takes into account many of the engine and driving parameters that effect oil life.
If you have lots of cold starts, drive short trips, spend a lot of time in stop/go traffic, eat a lot of road dust, or do not spend sufficient time at operating temperature, then you are running "severe" conditions. 4000km (2500 miles) seems to be a common number for many folks. I change at 5,000 - 5,500 miles (or 6 months but that never happens!) and only got the chime once. Mobil 1 oil and filter. if the synthetic is emptying your wallet to quickly, just use a good brand of dino. But personally, I would make the change when alerted. P.S. FWIW I always have a spare Napa Gold filter and 6 litres of Mobil 1 5w20 synthetic at the house, good synthetic oil definitley isnt cheap and might seem like overkill to some but knowing thats what I have in my engine gives me a little peace of mind. |
Originally Posted by JackMac4
(Post 1534156)
Nope, it was added I think for 08s or 09s. I have never seen an 07 with it.
Software update perhaps? |
Originally Posted by Adam3612
(Post 1534781)
Are you sure? I changed my oil at the first of October with just under 26 000 kilometres on it reset indicator when I was done, now have just over 30 000 and it came on last night. The oil appears to be fine, which it should be considering its Mobil 1 synthetic and its only been in there not quite 4 months. I think these things are kinda screwy if you ask me because this isnt the first time the indicator has come on way too early. According to the manual we can go up to 10 000 km's er 6 months between oil changes, (not a freakin' chance in hell I would try to pull that off).
up, up, down, down, left, right, left, right, B, A, B, A, start..................wait that's for Contra.
The previously posted method is correct. Do people really need a light to tell them when to change the oil!?!?!?!?!? pain in the butt |
Originally Posted by Alf1096
(Post 1535074)
I don't have a hoe to reset my light:rotflmao2:
[QUOTE=mjolnir;1538255]up, up, down, down, left, right, left, right, B, A, B, A, start..................wait that's for Contra.
Now that brings back some memories |
I tried the pedal method and my light did not go off...I have tried it numerous times. Any other methods?
same problem
I tried resetting the indicator - I've followed the manual's instructions multiple times and still the message comes on when I start the jeep. Any tips? Does the jeep have to be off for a certain period of time, quick pumps of the pedal or slow, etc? I seriously have tried this at least 6 different times with no luck, Im banging my head against the steering wheel at this point.
you are probably hitting the skinny pedal too quickly.
Hey it could be worse, wait until you try doing the steering wheel dance to permanently disable ESP :what?: |
You prob already figured it out but search on here to check your manual...both tell you how to do it.
