How do you remove plastic insert?
How do you remove the plastic insert in the rear swing gate on a JK? Want to run my CB/Ham radio antenna cable thru the door and under the plastic. Do not know if it just snaps out, etc.
Thanks in advance for the help.
2) Start from where cables go in and slowly lever up the lower corner. It will snap out
3) Go along and do the same for other 3 or 4 (can't remember) clips holding it
4) Pull off downwards
Reassemble in reverse
