How Far Can You Go on Low Fuel Warning?
Auto makers on average (car, truck) set the light to 20 miles left of fuel to get you to the nearest gas station.
I would suspect Jeep (being an all terrain vehicle, where Jeep knows your offroad on a trail often) has doubled the miles for the light. 40 miles, I tried it on road so I would know for Offroad times.
Its kinda annoying being so early but it makes total sense for an Offroad vehicle.
I just did this this AM. fuel light came on about 15 or so miles ago, watched the DTE run down to 30 miles left, then read lo Fuel. About 2 miles later filled the tank and put in 15.2 gal. So, I had about 3 gal left. I'll probably continue running it down to about that level if I'm in-town.
I don't really buy the cooked fuel pump theory, unless someone can explain I'm wrong. Is the fuel pump immersed in the gaoline in the tank? That doesn't sound like such a good idea. If it's just cooled by the fuel flowing through it (most pumps are cooled by the liquied they are pumping), then as long as you don't run out completely you're good. If you do run out, just turn off the ignition and it stops, and doensn't burn up.
My light comes on when dte hits 35 or so, and if if up right away I
Can only but 17-18 gallons in so there is still at least 4-5 gallons left
Try not to push it to hard
(sorry)
