How to unplug the connector for the ABS module?
I'm in the process of installing an M&G brake system so that I can flat tow my JK. To do this, I have to relocate my ABS motor slightly forward of it's current location. The problem is that I'm not sure how to unplug the connector. I'm sure there are some locking tabs that need to be released but I don't see them. Has anyone unplugged that connector? If so, how did you do it?
Ok, I figured it out. For future reference for someone else...You squeeze the two small tabs (one on each side of the connector) and pull the bottom out so that it rotates up. It doesn't actually pull out. It then will allow the plug to come out.
