I broke something
Old Jun 11, 2011 | 03:55 PM
Danabee's Avatar
Default I broke something
I was out doing some light wheeling today, just running around some washes, and something in the rear end started clunking, wheel hop, especially when turning. Any Ideas? Broken axle, rear end?
Any advice?
Dan
Old Jun 11, 2011 | 04:09 PM
Biginboca's Avatar
I would check the trackbar mounts first, both axle and frame but especially at the axle.
I say this not because of your symptoms but because it is a known weak spot, especially at the axle.
Old Jun 11, 2011 | 04:40 PM
Mark Doiron's Avatar
Not really the rear end, but this didn't happen when shifting in or out of 4WD, did it? Transfer case shifter linkage is a known weak spot. Otherwise, crawl under Jeep and see if anything looks unusual. Also dip finger into rear diffy fluid and ensure level and quality are okay. It may smell foul, but not burned. You may want to pull diffy cover and eyeball things.
Old Jun 11, 2011 | 04:42 PM
Danabee's Avatar
Everything looks ok underneath. It will not move in two wheel drive at all. I think something really broke.
Old Jun 11, 2011 | 04:46 PM
Exactly what does it do/sound like now when you try to drive it?
Old Jun 11, 2011 | 04:53 PM
Also, is this a six speed or an auto? BTW: Xfr case problem I mentioned can cause vehicle to be stuck in neutral. Does the xfr case shifter feel solid/normal?
Old Jun 11, 2011 | 05:12 PM
Danabee's Avatar
It is an auto, and the transfer case works. It makes gringing,clanging noises
Old Jun 11, 2011 | 05:22 PM
srunyon's Avatar
sounds like an axle shaft.
Old Jun 11, 2011 | 09:47 PM
mkjeep's Avatar
Put it in neutral, jack up the rear and see if you can spin the tires by hand.
Old Jun 18, 2011 | 11:14 AM
Danabee's Avatar
It was the spider gear.
