Idle issue help!!!
Old Mar 21, 2020 | 12:33 PM
Kasseyok's Avatar
Default Idle issue help!!!
2007 Jeep Wrangler
3.8 V6 230,145 miles
Engine idles at 1,000 rpms and once it gets to operating temperature it sounds like it wants to die.
Replaced
Map sensor
EGR valve
Evap canister with leak detector
Evap purge valve
Evap line to purge valve and to evap canister
Catalytic converter
Oxygen sensors
Throttle body
PCV valve
Spark plugs
Spark plug wires
Alternator
Coil pack
Cylinder heads
Head gaskets
Head bolts
Fuel injectors
Fuel injector Wiring harness
Thermostat
Radiator
Coolant temperature sensor
Exhaust manifolds
Lower intake manifold gasket
Upper intake manifold gaskets
Just put 93 octane gas in it.
The coolant has been replaced
The oil has been changed
Haven’t replaced
Computer
Camshaft position sensor
Crankshaft position sensor
Old Mar 22, 2020 | 06:34 PM
Mr.T's Avatar
Community Favorite
Lightbulb
The DTC's in the vid point to a vacuum leak, possibly in the evap system. I'm betting that you have already plugged the vac line to the evap system too see if it will idle normally -- If no, give that a try. There's also a smoke test for vac leaks too.
Maybe it's the timing chain, the cam timing off enough to lower manifold vacuum and it looks like an air leak to the PCM??? Here's a link to test I came up with for checking the slack in the chain. Kind of a long shot since there's no related DTC and you didn't mention any chain noise, but it's cheap!
Were all the parts replaced to fix this same issue, and was there any change in symptoms or DTC's? How did the problem appear initially? Some history may help.
Old Mar 24, 2020 | 06:23 AM
Kasseyok's Avatar
I haven’t done anything to test the vacuum line.
I took off the timing chain cover to replace the gasket because that’s where it was actually leaking from and the timing chain is tight, I checked that when I took the cover off.
History: started out as a coolant leak and had some bad injectors so I just started replacing things as I went along no real reason just had a lot of miles on it and everything was still stock.
It was leaking coolant so I replaced the head gasket and the intake manifold gasket and it’s sat in my garage for a year so I put it back together and started it and then it sounded like it does now.
Going to try seafoam to clean but also because If there is a leak it might have seafoam come out of it? Maybe never done the before
Old Mar 24, 2020 | 10:59 AM
Mr.T's Avatar
Community Favorite
I can't see how seafoam will help. Can you drive it on the highway? If yes; How does it run under power and does it generate any more codes?
Old Mar 25, 2020 | 11:32 AM
user 729872082's Avatar
Former Member
Still sounds like a vacuum leak. Since it started with the head and intake manifold change I would guess there is something not right there. One way simple way to find a leak on the intake side is to skirt some WD40 around the intake manifold gasket area. If there is a leak the idle picks up and then of course drops back down.
