View Poll Results: Replaced idler pulley from mud/water?
Yes one time
13
11.30%
Yes more then once
7
6.09%
Not yet
95
82.61%
Voters: 115. You may not vote on this poll
Idler pulley
Old Jun 5, 2009 | 10:44 AM
  #31
tkob1060's Avatar
From: Hangin in the sunshine state....staging forum..
Originally Posted by Mr. T
i just have to laugh. putting in idler pulley number 6 later today. 6! and i have number 7 in my jeep for when this one goes.... 16 bucks at napa. not too shabby.
damnit tom I think you are ahead of me now by one, I gotta go get muddy haha
Originally Posted by falconfixer
J. I knew better then to play in the silt crap but if the worst thing out of a weekend is a half ripped off air dam and a blown idler pully, I call that a good weekend.
x10000 its a good weekend and cheaper then going to a movie for 2hrs
Old Jun 5, 2009 | 11:00 AM
  #32
tkob1060's Avatar
hey, what's the big pulley below the idler? below it and more towards center? anyone got a diagram with all the pulleys labeled?
that one I think it is the timing chain/camshaft, the bottom one is the crankshaft dampner pulley
Old Jun 5, 2009 | 11:08 AM
  #33
tkob1060's Avatar
thanks. it's friggin crazy in there right now. one squeaks, so, shot it with some white lithium, and then another squeaks. hit that one, another squeaks. it never freakin ends...
what yo still have the noise? it maybe your tensioner pulley, thats the one you put the ratchet in to loosen belt, the pulley that is bolted to that is the same as the idler and you can unbolt and bolt on one of the idler ones to replace it, Pagoda did that, its hard to tell whats what sometimes because of the belt spinning and carrying the noise.
I dont believe the crank or timing/cam one has bearing in it on the outside, the other it could be is the a/c and easy to check that turn a/c on and it noise changes/stops almost thats it
Old Jun 5, 2009 | 12:39 PM
  #34
Bodo's Avatar
Have not replaced mine on my JK but I did have to replace one on my wifes 03 liberty at only 8000 miles. We started hearing this squeak, squeak, etc,etc while idling. The OEM and the replacement looked like complete JUNK.
Old Jun 5, 2009 | 12:44 PM
  #35
tkob1060's Avatar
i haven't swapped the idler yet. i'll wait to do that and see what else there is. the noise is definitely coming from either the idler (most likely), the alternator (i hope not, it's new) or the timing/crankshaft one. it is definitely coming from the right of center side, and more towards the top. once i switch the idler, i'll be able to easily isolate whatever else is making noise. just over 400 miles left on the warranty. if the idler doesn't do it, the dealer hopefully will.
I EXTREMELY doubt that its coming from the timing or crankshaft one.
