Immediate help needed!!!!!
Old Oct 16, 2009 | 02:57 PM
Default Immediate help needed!!!!!
I am trying to get my rear diff cover off to fix a leak and i cant get it off for the life of me. Any tricks??? I took all the bolts off the front am I missing some??? HELP ME PLZ!!!!!!
-david
Old Oct 16, 2009 | 03:04 PM
been trying that with a chisel and screw driver but have no luck, ill go try with a scraper.
=david
Old Oct 16, 2009 | 03:51 PM
yes it was the first time and wow, that should not have been that hard, but eventually it came off. thanks for the quick responses, much appriciated!!
-david
Old Oct 16, 2009 | 05:30 PM
jonc's Avatar
If u r trying to get the rear diff cover off - yoh have to take the bolts off the rear! Not the front.
Old Oct 16, 2009 | 05:35 PM
Oh man, that could be why........ i thought the bolts when all the way through, from the front diff to the rear diff. Glad I have these forums to help me out.
Old Oct 16, 2009 | 06:19 PM
If you went at it with a chisel and hammer, be sure to inspect the two mating surfaces very well. one good gouge and you may have sealing problems, Just sayin.
Old Oct 16, 2009 | 06:28 PM
thanks for the help, I hardly used the chisel and never hit it very hard, was just trying to get some of the silicone out with it. Best part is the seal that I applied looks much better than the old one, i have a nice ooze all the way around the cover.
Old Oct 16, 2009 | 06:40 PM
Rub61's Avatar
Have removed covers many time and the best method for me is to wack the thing from the side with a dead blow hammer. They seem to just pop right off.
I have switched to Lube Lockers in lew of RTV. Less mess and if you bounce off of a rock the thing doesn't shift and start leaking.
