IMPROPER transfer case shifting
There is constant complaining about the shifter for 4WD lo/hi coming loose or breaking. If shifted incorrectly the shifter cable will pop off or the end will come unsnapped from the shifter or transfer case. The proper way to shift into 4WD LO is to slow to a BARELY MOVING ROLL, put the tranny in NEUTRAL, let off the gas and BRISKLY pull the shifter down into 4LO. The purpose of the roll is to take the torque load off of the gears in the transfer case, enabling it to be shifted easily without causing damage to the unit. The cable is designed to fail if the Transfer case is shifted iincorrectly. After a few shifts you will learn the ''sweet spot'' and the shift will be accomplished with nary a grind. Attempting to shift without the vehicle rolling slightly and foot off the gas creating ''slack'' in the driveline will result in a broken or detached cable, sooner or later. Usually sooner. A lot of grinding when shifting into 4 LO doesn't mean there is a defect in your transfer case or cable, they are trying to tell you your shifting method needs finessing. I've got 50,000 miles on my JK, shifted into 4WD frequently with no problems. Try this advice, it really does work. It's right out of the owner's manual.
I do agree, it has a lot to do with operator error i think. Even if you are stopped you can feel it roll into gear. If it's "firm" before engaging you can roll (literally an inch) and it will fall in. All with some finesse!
I haven't broken mine yet. I think heat as a lot to do with the clip breaking even when one is careful.
Shifting my JK t-case appears to be exactly the same as my XJ and MJ were.
When I had those vehicles, I didn't have the benefit of an internet forum, so I didn't hear if the shift linkage would break off like the JK seems to.
Was that a problem on the XJ/MJ?
The JK cable is designed to fail? Probably, but I bet it wasn't on purpose.
As soon as Novak Adaptors markets their JK t-case cable, I'm getting one.
At first my Tcase was stiff, set the ebrake start the jk, take it out of park to neutral
rock the auto from neutral to rev then to drive back to neutral while shifting the Tcase
that worked for me smooth as silk good luck
I thought along the same lines as the OP (that incorrect shifting was the sole cause of clip breakage, the plastic clip itself being a cleverly engineered "weak link" in the shifter assembly designed to avoid the damage of other components) until my clip fell off & the cable came loose just by driving along on the beach & on sandy trails.
Being on a remote sand island without any mechanical facilities I was paranoid about mechanical failure so even though I shifted into 4Hi on the barge on the way over & left it there for the week, I still got under the JK every morning to check that everything on the underside including the clip was where it should be.
And sure enough one morning the clip was gone & the cable was hanging loose, even though I hadn't gone near the shifter for a week. Lucky I took the advice of others on this forum & carry a bag of zip ties in the glovebox at all times.
Always let mine roll while shifting into 4lo and it's smooth as astroglide. After watching my brother in law try to slam the shifter of my sisters brand new rubi into 4lo repeatedly with his foot on the brake while i watched in horror from my jeep...I would put money on 75% of the cable failures happen as a result of user error while trying to shift into 4 low. Probably not that high of a percentage on this forum though.
If my experience today means anything here is what happened: I checked that everything was working properly at home, I drove about 40 miles on pavement to get to the trail, went to shift into 4h at the trailhead and found the cable off and the white plastic bushing gone.
Over time the plastic bushing (which sits inches from the exhaust) gets weakened from the heat and simple road vibrations will cause it to crack and fail.
