The infamous soft top leak
Old Dec 13, 2010 | 02:26 AM
CFonda's Avatar
Default The infamous soft top leak
Does anyone have a cost estimate on fixing the soft top leak at the A-Pillars? I've tried foam tape, weatherstripping, and everything in between and I still have periodic puddles on my drivers side floor and seat. Getting quite tired of this.
Thoughts?
Old Dec 13, 2010 | 02:52 AM
horrocks007's Avatar
Find a new soft top shell on craigs list. If it still leaks, it could be your install methods.
Option 2. Tupperware on the front seat to catch the water.
Old Dec 13, 2010 | 03:55 AM
Bling's Avatar
I solved my soft top leak permanently by using a very small amount (a ball less than the size of a green pea) of that putty-like sealant that never hardens. You can get it at any of the "big box" home improvement stores. Some trades people call it "monkey poop" or "dum-dum".
Apply it at the aft end of the shaped rubber gasket (the odd shaped piece just aft of the A-pillar) so that it seals tightly. I would get pics but
1. It's friggin cold and snowing here and
2. the hard top is on...
You shouldn't need a new top or that gasket unless one or both are damaged.
Old Dec 13, 2010 | 05:06 AM
CFonda's Avatar
@Bling - I may give that a shot. If you happen to come across any pictures of the repair, it would be greatly appreciated!
Thanks!
