Interesting MPG Observation
Old Aug 24, 2011 | 03:07 PM
Mark Doiron's Avatar
Originally Posted by Wrangle_on
Did the gas formulation change any? Ethanol in the gas will cut mileage noticeably.
That's the trouble with these anecdotal reports: They mean very little without scientific rigor applied. I removed my MBRP-equipped hardtop and tools and experienced approximately a 1 MPG improvement in gas mileage. But how many folks keep track and admit they bought gas at a different place, removed unnecessary gear, had different weather, etc? MPG numbers quoted on this forum are extremely unreliable ... including the one I just quoted!!!
Old Aug 24, 2011 | 06:57 PM
tpm152's Avatar
The reason I would say that this takes into account ethanol gas is that around here in PA where I usually get 22 - 23 mpg on the highway most stations I fill up at say "contains 10 percent ethanol". Also it would be awful coincidental that after filling up for 3 months at all types of different stations (Exxon, Conoco, Kroger, HEB, Fast Track, etc.) and getting 18.5 - 19.5 mpg like clockwork, that as soon as I got to a place where the ambient temperature got below 90 the fuel economy that I started getting the same fuel economy I see in PA.
Old Aug 24, 2011 | 07:14 PM
1st timer's Avatar
Originally Posted by Whilton777
I'm interested now bc of what 1st timer said.... I have an 09 4dr Rubi with the 6 speed and I'll be doing good to get 17 on the interstate and 14-15 around town. I run 87 tho so I think I'll try 89 next fill up and see if that makes a difference......
So... Computer was showing 18.4, and my manual check was 17.85. Hmmm...
Old Aug 25, 2011 | 04:27 AM
ClaytonT's Avatar
Speed is the difference maker for me. I've done a few State College trips and if I try to keep it at 70 I'll use over a tank. Two weeks ago I kept in right around 60 and made it with over 1/4 tank left.
I did Jacksonville, FL to State College and kept at 60 the whole time, my numbers worked out to just over 25mpg.
Old Aug 25, 2011 | 04:31 AM
WXman's Avatar
I track my milage in a spreadsheet. I document where I fill up, when I fill up, any weather conditions, driving style, mods done to Jeep, etc. So I know EXACTLY what helps and what hurts.
I was pulling a consistent 17 MPGs in July in very HOT weather all month. So far, August has been cooler and I'm seeing a solid 18 MPGs. This is with everything else constant.
Is it just the cooler weather? Or the fact that the A/C stays on less? I don't know, but below-90 weather DOES = better mileage for sure.
Old Aug 25, 2011 | 06:10 AM
1st timer's Avatar
It's been much cooler here in Western KY as well. The only time I run the AC is when the kiddos are with me. Other than that.. I don't care if its 100, I still have at least the windows down. I do notice a difference in MPG when I'm running the AC, but since I don't use it that much, I have to assume it's the cooler temp outside.
That 17.8 that I'm getting is me babying the pedal. This is on a Unlimited auto with 3.73. If I drove it like I do my wife's Commander, I'd prolly only get 15 or 16. Most of my driving is short commutes. 15 miles to work with hills and cut through one small town.
Old Aug 26, 2011 | 10:59 AM
GearWhore's Avatar
I've noticed over the last several years that my mileage peaks in the moderate temps of spring and fall, with usually an extra 1-2 mpg. This was the case in my WJ as well as my JK. I have also noticed altitude does play a part, though not as much as temps seem to (at least in my JK).
Another part of this, I've noticed the mileage readout from the trip computer is regularly about 2-3mpg off in my Jeep. I have been tracking all of my fuel and maintenance with an iPhone app since I got my JK 2 years ago, and it makes a big difference being able to have the backlog of data. I used to keep a log in my old XJ on a notebook, but found I got lazy way too often.
Old Aug 26, 2011 | 12:53 PM
xerofall's Avatar
I just plan on paying $75 per fill up. Anything less is just a little bonus. There are just too many variables when it comes to fuel economy.
Instead, focus on finding a gas station that has the lowest costs, reduce your weight by not carrying all your gear when its not needed, and obey the speed limit.
Old Aug 28, 2011 | 09:45 AM
barnettd's Avatar
Default a/c
the biggest mpg robber by far is my a/c... followed by a strong head wind! I drop a couple of mpgs on the same commute with a/c on. Since the idea behind "cold air intakes" is to seek cooler air it can't help with the temp drops into the 70s or lower.
