Interior Heat? What have you done to keep it cool?
Old Aug 26, 2010 | 03:04 PM
  #51
Patchules's Avatar
Default Have foil bubble stuff for now
I lined the JK with Reflectix for now. In my 05 Unlimited, I used a foil backed insulation designed for firewalls. Glued it to 1/8 Luan panel with carpet like material on the other side. Also painted the very top part of the roof white.
I have a gallon of Bus-Kote waiting to be applied to the JK. Top needs to be cleaned, degreased and a primer applied first. Maybe soon....., it's getting cooler.
Old Aug 29, 2010 | 06:39 AM
  #52
oregon signs's Avatar
my driver side floor cooks my feet. anyone else notice this?
Old Aug 31, 2010 | 01:19 PM
  #53
two_ton_anchor's Avatar
Veteran: Navy
You rip your carpet out? Usually that will transmit some of the road heat up into the cab. If it's running hot with carpet, I'd take a gander under the tub.
Old Aug 31, 2010 | 01:39 PM
  #54
wolfpuppies3's Avatar
Default No problem cooling mine easily up to 106 degrees so far
The only change I made was to install hothead headliners on roof and around side windows. Of course I have the hard top.
