Issues after 3000 miles
I'm about to take my X in for the following issues, but I figured I would check the forum first, since they probably won't have much of an answer for me.
1. My starter gets stuck occasionally, it's only happened about 5 times in almost 2 months of driving, but.......it does happen.
2. The driver's door sounds like it's flexing or something, like I hear a tapping noise in the door, it's shut all the way, it only happens about 50% of the time, but it is annoying.
Other than that, I have loved it, I know these are knick picky, but hey I spent 26k on a vehicle, so I can complain a little.
Let me know if you have any of the same problems or solutions.
This morning when I started our new JK (week-old owners tomorrow) the starter stayed on past the point where I let go of the key, about 1/2 second or so. I was wondering if it was a feature-- the starter stays on until the engine is started (if that makes sense).
It's the first time this has happened with my Jeep, but it's also the first time I was starting it in 15-20 degree weather.
I start it and the starter gets stuck in the start position and won't stop even when the engine starts. A couple others on the forum have the same issue.
I think what I experienced this morning is different than what you describe, then.
Lucky Bastard.
I had the dealer try to fix it, doesn't do it often.
How cold is it where you live. I have thought about installing an engine coolant preheater on mine. Not only do you have instant heat, but you have faster startups and you reach operating temp quicker.
I reached up while driving yesterday & hit my seat belt attachment above your head on the left and it made same sound I've been hearing.(maybe going to put some foam inside the attachment) It bounces up & down and a clunking sound appears. Try it...just maybe.....
I turn my key to start it & immediately release it, & it starts right up....I don't hold it in the start position anymore.
Yeah I will check on the seat belt, it definitely sounds like it's in the door. Far as the starting issue, I might just not be releasing my hand quick enough, but it does it in hot and cold weather, and well I live in Charleston, SC, so there never really is any cold weather.
I am also getting a tapping noise from my door like it is flexing. I am hearing it from the top right near the windshield. I think it could be the plastic cover that is removable for folding the windshield down, but havent had a chance to play around with it to figure out for sure.
