Jack for maintenance
So, I was going to rotate my tires over the weekend, and my hydraulic jack could not even reach the axle.
What jack do you use for maintenance? I currently don’t have a lift and stock wheels/tires but I plan on going to 35's down the road.
What do you use?
I plan on getting a jack and jack stands
Thanks!
What do you use?
Thanks!
Go to harbor freight and pick up a 3 or 4 ton jack. Measure ground to jack point and make sure it will lift the jeep high enough in order to get jack stands under there. Sorry i cant remember the brand i have but it's a 3 ton jack and i have four 3 ton jackstands.
Right now Harbor Freight has a heavy duty 3 ton quick pump jack that goes 6-18" for $89.99 and 3 ton jack stands for $24.99. Periodically they have really good sales where the prices can drop up to 25%.
Ask for a January HF 25% off coupon at the register.
I bought the 3 ton aluminum jack for $120 with the coupon.
Works awsome, lifts the whole rear eand so I can drop stands under each side.
Get some really tall jack stands too! takes a lot to droop the axle on these things.
A small piece of a wood block between the jack and the pumpkin helps fill the gap to. I have a chunk of pressure treated 4x4 i keep with my 2 1/2 ton floor jack. Works for me with 33s. Then I have tall 3 ton stands to support.
I use the dif in the rear with a 2x4 in between the jack and the dif just to avoid metal on metal and have never had any problems. Up front i usually just use the LCA mounts again with the 2x4 in between. lifting from the dif up front is always a pain because it is off centered so it takes to long to get both wheels of the ground… laziness
