Jeep clicks 1 and 2nd time then starts
Question, when i turn the key on the Jeep it just clicks the first and second time. However on tje rd it starts. I just replaced a month ago a brand new battery. Any help is greatly appreciated. I thought maybe the starter or alternator
Check battery cables (including ground connections) first. Maybe have someone tap on starter when it fails to crank while you're holding key to start. If it kicks on, pull starter and have checked at auto parts store. Also check for something draining battery when Jeep is parked. Check voltage when you park (engine off), then next morning. Shouldn't change more than a tenth of a volt or two. Probably not alternator, since it is keeping battery charged enough to start engine. In TIPM is a starter relay. Might tap on it while trying to start. Or listen with stethoscope to see if it clicks. If not, could be wiring to ignition switch, or switch itself. This diagram may prove useful ...
https://goo.gl/images/U1dfAC
It is a automatic. However when i start up it is kinda of sluggish for a few seconds and then is fine. I am starting to think it is the fuel pump now because of the situation that just happened
OK, I'm sure the fuel pump is making the starter click as you've described. Good luck!
Well when i take off and accelerate sometimes it's sluggish sometimes it's not. What do you suggest i do ? Also check engine comes on every now and then
Run a 4gauge ground wire from the Negative terminal on the battery to the alternator bracket. This usually takes care of the starter click issue and the neutral safety switch issue.
Had the same issue which cleared up after adding the new ground wire.
