Jeep Specific Tools
Old Jul 24, 2012 | 07:12 AM
Johnny-5's Avatar
Originally Posted by Rubichronic
Here's my list. I have most of it. This is specific to my jeep though. Some sizes may be different because of certain mods. All the ratchets, sockets and wrenches fit in a small plastic tool box. Almost small enough to store under the back seat. For now I keep it locked in a Stanley Fat Max Truck box that fits snugly behind the rear seats, along with fluids and recovery gear. I plan to make a trunk type set up eventually.
JK Tool Kit
Suspension and Steering components - I have all these sizes in 1/2" drive sockets and wrenches, with some extensions and will add some elbows (I think thats what they are called). Some of the smaller ones I have in 3/8" drive as well.
Front Suspension and Steering Components
Upper Control Arm - 18mm
Lower Control Arm - Frame 21mm
- Axle 21mm (mine is 22mm as I have an aftermarket skid with different bolts)
Swaybar Links - 19mm
Trackbar - 21mm
Shocks - Upper - 17mm
- Lower - 18mm
Steering Stabilizer Shock - 18 mm
Steering Stabilizer Pinch Bracket - 15mm
Draglink Pinch Bracket - 15mm
Control Arm Lock Nuts - (stock doesn't have these but my RK Control Arms do) 1.5" box wrench or adjustable (not sure on this size)
Rear Suspension
Upper Control Arm - 21mm
Lower Control Arm - 21mm
Swaybar Links - 17mm
Shocks - Upper - 16mm
- Lower - 18mm
Trackbar - 21mm
Trackbar Bracket- (stock doesn't have this) - 22mm (Rock Krawler)
Axle Nut - 35mm or 1 3/8" (some might be 36mm)
Driveshafts - 8mm/15mm??
Brake Components
Front - Calipers - 13mm/1/2", 15mm open end wrench
- Pad Carrier - 21mm
- Brake Line - Caliper - 15mm
- @ hard line - 12mm/17mm
- Hub Bearing Unit - 13mm 12 point socket
Rear - Calipers - 13mm/1\2", 15mm open end wrench
- Pad Carrier - 18mm
Brake Lines @ Master Cylinder - 12 mm
Brake Booster/Power Steering Bracket - 13mm
ABS Sensor - Allen Key 18mm
Battery and assorted grounds - 10mm
Alternator - 15mm
Throttle Body Adjustment - E10 reverse torx
Transfer Case Fill Plug - 10mm allen head
Transfer Case Drain Plug - 10mm allen head
Transmission Fill Plug - 14mm allen head (manuel)
Transmission Drain Plug - 17mm allen head (manuel)
Bottle pump to fill transfercase/transmisson (manuel)
Torxs Sockets for doors and hard top, and windshield - T50, T40, T35
General Tools
1/2", 3\8" drive torque wrench rated between 20 and 150ft. lbs.
Vise grips
Needle nose pliers
Soldering Iron, flux and solder
BFH
Wire strippers
Duct tape/Gorrilla tape
Assorted zap straps/Zip ties
JB Weld
Electrical Tape
Tie Wire
Assorted Fuses
Multi Meter
Breaker Bar
Code Reader
Heavy Duty Ratchet Straps
Funnel/long neck funnel
Utility Knife
Small Tarp
Hand Cleaner/Latex gloves
Rags/Shop towels
Spill Kit
Thank you for this list! I've been reading the Jim Allen book, and this was my next project.
Old Jul 24, 2012 | 07:42 AM
Nibsirb's Avatar
Def what i was looking for Rubichronic!!! I def. won't be carrying all that with me all the time, but it does help to build a pretty sweet pack for those off roading days!
Old Oct 12, 2012 | 01:21 PM
silverwrangler's Avatar
hi all
I would add a 3/4, yes!, rachet or breaker bar and 30mm 32mm 36mm sockets for the big stuff. Also I use a 1/2 breaker bar and IRC 3/4 inch socket for tire lug nut removal, better then stock set. Also at home use el cheapo (Harbor F) 1/2 impact drill for tough lug nuts. Too many sprained injuries for old timer. Good set of pullers from 2 jaw to big 4 jaw. and clamp looking thingy you tighten to pop out tie rod ends. Also have 20 piece clamp and socket set for ball joints and ujoints.................I will remember more stuff later..............
