JK automatic transmission bushing?
Old Jan 13, 2015 | 11:25 AM
mmayo's Avatar
Default JK automatic transmission bushing?
where can I find just the bushing??? I'm not looking for a temporary fix & don't want to replace the entire cable. Does ANYONE sell just the bushing??
Old Jan 13, 2015 | 11:39 AM
101gargoyles's Avatar
Former Member
I'm not sure if they are the same without crawling under the Jeep in the snow but I have info for transfer case shift cable bushings. Dealership sells them for about 30 cents a piece. I bought 4 and never needed to use any before replacing cable with the Advance Adapters one. My original cable seized up.
Part # for my 07 was 68064273 AA.
Old Jan 13, 2015 | 11:47 AM
mmayo's Avatar
They are not the same - that's what I have on it now, but it will fall off....I've seen guys use them along w/ zip ties but that's not a long term solution.
Old Jan 13, 2015 | 04:50 PM
mmayo's Avatar
Anyone???
Old Jan 13, 2015 | 05:33 PM
Rebar-7's Avatar
This is the new part #68064273AB ( 2007-2013 ) same part number as old but the AB indicates
The update to the part. Made from Diff material , nylon I think instead of plastic.
Old Jan 13, 2015 | 06:09 PM
ronjenx's Avatar
That's the transfer case cable bushing.
Anyone know the number for the automatic transmission cable bushing?
Old Jan 13, 2015 | 06:11 PM
Rebar-7's Avatar
Oops my bad . So many threads on these bushings it gets confusing....
Old Jan 14, 2015 | 02:48 PM
mmayo's Avatar
Bump.... Someone has to know ?
Old Jan 14, 2015 | 06:34 PM
Rebar-7's Avatar
Moparonlineparts.com. All you want...
Old Jan 15, 2015 | 11:48 AM
mmayo's Avatar
thanks - but I don't want to buy the entire shifter cable --- I just want the bushing!
