JK wandering after installing new ball joints
Does it feel like the front wheels fight each other? And the JK's front is "nervous"? Does your head bobble side to side?! ![Wink](https://www.jk-forum.com/forums/images/smilies/wink.png)
Toe too far in or out will do this. This site suggest 1/8" in. That's a good starting point. I ended up aiming for 0 toe. My JK with steep (low number) caster angles tracks better that way.
Took the JK to a new allignement shop. it was toed out abou 1/2 an inch. I had them adjust the toe in to 1/8 of an inch.
also I got all the front control arms bushings replaced. With this allignement, the new bushings, the new tie rod/ drag link ends and the new ball joints, the JK rides like a dream even better than stock. I couldnt be happier
![Big Grin](https://www.jk-forum.com/forums/images/smilies/biggrin.png)
Great to hear. I'm curious what the castor settled out to...there is some discussion on the above alignment thread on higher vs lower castor angles. Eddie recommends 6 deg for tires greater than 35" whereas Fletch recommends lower angled values...and yet another here for lower angles...
Thanks guys. I was having the same problem after changing my ball joints. I found this old thread and sure enough I had over tightened. Backed the nut off a bit replaced the keeper pin and now roles straight and true
![FJOTM Winner](https://i.ibb.co/FgFLpFN/Untitled-1.jpg)
You need to make sure those are tightened to spec. It's usually not that you've overtightened them as much as it takes a little time for them to wear in. You should give them 500+ miles to settle in a bit.
