JK wont start after oil cooler change - PLEASE HELP
PLEASE someone help! So I had a coolant leak which I believe was coming from oil cooler. I removed all and change oil cooler with OEM, replaced gaskets and cleaned out everything, I went to go start it and now it wont kick on. Let me add that the engine was running flawless other than the leak prior. Sounds lie it starts than dies. I also have the lighting bolt flashing now. Please someone help if you have had this problem in past. Thanks in advance!!
The lightning bolt on the dash means that there is a problem with the electronic throttle control system in your vehicle. Get a code reader and scan the engine for any logged codes. The light may be on for a glitch and the electronic throttle control system needs to be reset.
