JK-X jumping front end on hard turn, 4wd
Actually, you're all three wrong The problem isn't with the front wheels trying to turn different speeds, or the rear wheels trying to turn different speeds. The differentials in your front and rear driveshafts take care of this (unless you're locked). All four wheels always spin at different speeds in any corner, that's what differentials are for. The driveshaft speed is always equal to an average of the tire speeds for each axle.
The problem is that the average of the speeds of the front tires is greater than the average of the speeds of the rear tires, and there is no differential in the transfer case to allow this to happen. Since the t-case always spins the front and rear drive-shafts at exactly the same speed, but the front tires need to go faster than the rear tires in a turn, they drag or scrub.
This is also the reason why the brake-lock differential technology on the JKs can cause a jerky ride off-road. When your computer senses a wheel start to spin, it applies the brakes to that wheel to try to control the wheel spin. If you have a situation where 3 tires have good traction and the fourth wheel is spinning, when the computer applies the brakes to that wheel, then the other wheel on that axle is trying to spin TWICE as fast for a moment. It can make for some jerky performance.
-E
-E
Now I'm confused. So if you're not offroad, when would you ever use 4wd? Just in the snow? In my Liberty I sometimes switch to 4wd hi when it's raining and I'm at a stoplight and I know the wheels are gonna spin. Should I not do that? I always switch it back to 2wd once I start moving.
And if I had to take sides inthe left wheel right wheel vs. front wheel back wheel debate, then I choose Jake. The brakelock rant took things a little away from the root question.
Since wrangler Chuck didn't make mention of locking the axles, I'd go with jake's explanation. I completely agree with the lockers having a similar effect.
This keeps getting muddied, but 4 lo does not turn off the brakes attempts to simulate a limited slip.
KJ (Liberty) has 4HI / FULL-TIME which works like AWD and can be used even on the dry pavement (front 45% / rear 55% power - unlocked).
I wouldn't use 4HI / PART-TIME for rain (front 50% / rear 50% - locked). ESP is there for that. That said, if I'm on the very steep hill (there are many here in Seattle) and I know it's going to spin/slide because of snow or heavy rain, I probably use it just to get going... as long as you go straight (up), it shouldn't be any problem.
You make some good points, however in a senes I think you just repeated part of what I said... and that was both front tires are wanting to spin at the same speed... since you're turning, one tire needs to travel further and one needs to travel less... therefore you will see the jerking front steering wheel occur. It is the same is if you were locked up... except when you're locked up, it's even more apparent - big time.
The problem is that your front drive shaft MUST spin at a speed that is the average of the speeds of the front left and front right tires. So if you're going around a corner at an average speed of 10mph, your right front might actually be traveling at 11mph and your left front at 9mph. Because of the way a differential works, your front drive shaft will be spinning at a speed that would make the Jeep go 10mph (11+9/2), even though the wheels are not moving at this speed. This is perfectly OK and will happen regardless of whether you're in 4wd or 2wd, that is what a differential does.
The problem is that on that same corner, your rear wheels might be traveling at 10mph and 8mph, for an average of 9mph that the rear drive shaft needs to make revs for.
Now, your rear driveshaft wants to spin revs for 9mph, and your front driveshaft wants to spin revs for 10mph. When you're in 4wd, this difference is transmitted directly to the transfer case, and binds everything up until something slips (either the front tires "push" or the rear tires "pull") or, eventually, something breaks.
In an "AWD" or "Full Time 4WD" transfer case, the front and rear drive shafts aren't mechanically linked and can spin at different speeds, so this binding doesn't happen.
-E
It turns off the electronic stability (roll & spin mitigation) but doesn't disable the brake-lock differentials.
Both front tires DON'T want to spin at the same speed. They want to spin at different speeds, and as long as you haven't locked up your diff, they CAN spin at different speeds. This isn't the problem.
-E
-E
One word. Snow. I got to use 4HI a few weeks after I bought the JK in the snow, no problems at all getting around town. Went to the fairgrounds parking lot and played some....OK, I played a lot...with all the different modes of forward travel, it was a learning experience with the computer wanting to drive some of the time.
I haven't done this yet, but indeed will. Haven't driving a vehicle like this before w/all the computer assisted stuff going on. Should be interesting. I'm kind of old fashioned when it comes to that stuff and always 'like to feel the road' below me... but from what I understand, this $hit really works... I just need to get out and play around with it to understand when I'm supposed to 'not fight' the computer and let it do its thing.
Basically, the answer is never run part time 4wd (or use your lockers) in high traction situations.
I don't know about the JK, but many 4wd vehicles don't even run the same gear ratios in the front axle as the back.
By the way, there is also another issue with steering/front end jerkiness, and that is U-joints. I won't even get INTO that mess, but read up on constant velocity joins vs regular u-joints if you're curious
-E
