Kinked lines going to evap purge solenoid - a problem?
After doing the Benchmark Designs dual battery tray install I found that the hard plastic hoses that connect to the evap purge solenoid have kinks in them. This is due to relocating the solenoid between the batteries and the fuse box.
I was wondering if I can replace these hard lines with soft rubber lines? I was wanting to mount the solenoid at the fender so it is not free hanging or zip tied to the fuse box lid (get in the way of opening). These are just vacuum lines right?
It tucks down between the TIPM and batteries and is pretty easy to zip tie to the TIPM brackets. If you orient it carefully, kinked lines shouldn't be a problem.
