Leak
2 Attachment(s)
I just bought a 2010 Wrangler Unlimited Sahara 2 days ago. Last night I backed it into the driveway (so it was on a downward slant). It rained quite a bit last night. This morning when I went to get in the jeep, there was about 1 inch of water on the floor on the drivers side and about 2 inchs of water (up to the seat bracket) on the passenger side. I attempted to find where the water had come from but I can not find it. The top and panals were on and I checked to make sure that it was on correct and it was. I checked all the pillars and found no moisture or signs of water. I am curious if this is an on going problem. Is there any other places i can check? maybe under the hood? Is there anything I can do to prevent this, like beef up the weather stripping? I know that its a jeep and will have some minor leaks but this seems like alot of water.
First you will want to pull your drain plugs to let the water out so it does not mold or rust. The hard tops are known to leak some have to worse than others. Mine leaks at the very front where the two freedom panels meet. You can try taking those off and looking at the weather stripping to make sure it's not damaged.
Just how tight should those freedom panel screws be???? It seems they could almost tighten endlessly!!!!!
Ive the same thing happen... The water was coming in through the bottom of the doors.. Took 8 visits to the dealer to fix the problem
I have the same problem. Never that much water though. I usually get enough to soak the carpet. Dealership has been absolutely worthless in helping me with the problem. Mine is also a 2010.
i just had hurricane Issac pass right over my house. for the first time mine leaked over the sound board a little. maybe a half of a cup total. and a little behind the rear view mirror about an ounce when i hit the brakes the first time after i got back in it. i guess that's not to bad since it had been rained on for 48 hours strait and subject to 70+ mile an hour winds the whole time.
so I took off the freedom panels and there are no screws that hold on the hard top and I do not have the freedom panel knobs that go through the sound bar either. So the only thing secureing the tops is the 6 screws in the back and the levers that lock the freedom panels near the windshield. I can push up the top by the B pillar almost 1 inch. I guess I need to get screws for the hard top near the B pillar and knobs for the freedom panels and see if that helps.
My guess is since I was parked on a decline the water made it through the door seam at the B pillar and ran into the front floor boards. |
I just found some water under rear passenger seat. Any ideas! Mine is a 2012 4 door
