leak help
Old Nov 12, 2011 | 07:21 PM
big c's Avatar
Default leak help
Changed the oil today and got the filter as tight as I can by hand and it has a vary vary slow leak it went on like butter and I oiled the ring and all I just don't get it
Old Nov 12, 2011 | 07:47 PM
codymac08's Avatar
Check your old filter to be sure you didn't leave the old oring on. If you have two orings then once you build oil pressure it will leak.
Old Nov 12, 2011 | 08:52 PM
big c's Avatar
I looked if over all looks well no leaks but looks like one was starting thks was an hour after I noticed and no drips we will see what happens in the.am
Old Nov 13, 2011 | 05:35 AM
big c's Avatar
It dripped once all night I got it as tight as I can go do I maybe have it to tight or what Idk
Old Nov 13, 2011 | 07:27 AM
blw's Avatar
blw
i'm always paranoid about this after changing my oil! i make sure to wipe off every bit of excess oil from the engine block before screwing on the new filter - maybe you had some residual old oil that dripped down...
Old Nov 13, 2011 | 08:39 AM
big c's Avatar
See I'm the same way its my first oil change on the jeep ( iv done them on past cars) but I'm all cautious that I might tighten something to tight or something stupid like that I dove the jeep around and got home and no leak so I think I'm good
