leaking
Old Apr 23, 2011 | 07:40 PM
mick0613's Avatar
Default leaking
just put on a used top I bought the first rain we had and my carpet is soaked , cleaned it up and turned water hose on it and water is pouring in around the front doors , on the top where the door close onto the surrounds and top meet any ideas on how to fix or something to look for would be great
Old Apr 23, 2011 | 09:42 PM
sa29560's Avatar
My JK with half doors did the same exact thing. Ended up doing a water test kind of like what you did and found the source. While I had the top down I prepped the leak surface and cleaned it all off and used some black silicone and a flathead screwdriver to fill in the area where water was pooling up. I think it runs behind the a-pillar in some cases as well dripping from right above the dash.
Old Apr 25, 2011 | 05:01 AM
RazorbackJeep's Avatar
Having a similar problem - vacuumed 3 gallons from the passenger side, can't find the exact leak location, but pretty sure it's in the front, either around the door pillar or around the windshield - there is water all along the seal on the inside. Taking it to the dealer today.
