leaking hardtop back window
Old Nov 13, 2008 | 06:25 AM
melliscj's Avatar
Default leaking hardtop back window
Anyone had issues with the rear window leaking on a 2 door hardtop? It only leaks in really hard rain. It seems to leak right near the wiper motor. At first I thought maybe the wires or tubing for the washer fluid were caught in the rubber weather stripping, but those were fine. Any ideas?
Old Nov 13, 2008 | 06:33 AM
jkkat's Avatar
Found mine was dirty. I cleaned it and put a touch of plumbers sylcone greese on it.
Old Nov 13, 2008 | 06:37 AM
CdnJeepDan's Avatar
I have a similar thing except I never notice the water until a day or two after a rain/snowstorm... I never actually see water coming in during a storm.
I think what happens in my case is if I open the tailgate the rear window pops out just a bit so some residual water from the top seal gets onto/into the rear wiper housing. Eventually tracks down the inside of the rear window.
My old TJ used to do the same thing.
Sounds like your seal might be a smidge short of making full contact with the window.
Old Nov 13, 2008 | 07:01 AM
melliscj's Avatar
That sounds like it. The water looks like it is leaking out of the box that houses the wiper motor. I though it was just a coincidence that the leak was right around there. I have an oil change coming up soon so I will have the stealership check it out. Thanks.
Old Nov 13, 2008 | 08:46 AM
porters's Avatar
My 4 dr leaked and they replaced the seal for me. After about a year it's starting to leak again.
