Lets Solve the Stock Springs Question
#661
Not sure why my "AFTER" photo doesn't work. I'll try again.
BEFORE
AFTER
Installed AEV rear bumper which didn't seem to drop the rear at all.
#663
I installed springs from a Rubicon JKU today. I went from a 14/56 set up to a 18/59.
Before (measured from the ground to the bottom of the fender aligned with the center cap of each wheel):
Left Front 35" 3/4
Right Front 35" 1/2
Left Rear 36"
Right Rear 35" 3/4
After:
Left Front 37" 1/2
Right Front 37" 1/4
Left Rear 37"
Right Rear 36" 3/4
So 1" 3/4 lift up front and exactly 1" in the rear. Rake is a little better and ride is improved. I'm glad I got them cheap while picking up these rubicon take off wheels. Nice easy upgrade.
Left Front 35" 3/4
Right Front 35" 1/2
Left Rear 36"
Right Rear 35" 3/4
After:
Left Front 37" 1/2
Right Front 37" 1/4
Left Rear 37"
Right Rear 36" 3/4
#664
Are you guys changing anything else in the suspension when doing the stiffer spring and rubi shock swap? Just wondering if I would need to replace control arms or something.
#665
I changed springs, put on longer shocks, added 1 inch bumpstop to the rear, longer front sway links. Links in the front is all that's really needed extra depending on tire size.
#666
While I was under the truck I also went ahead and swapped out the front & rear lower control arm and track bar bolts for Synergy's grade 9 hardware.
#667
Left Front 35" 3/4
Right Front 35" 1/2
Left Rear 36"
Right Rear 35" 3/4
After:
Left Front 37" 1/2
Right Front 37" 1/4
Left Rear 37"
Right Rear 36" 3/4
Left Front 35" 3/4
Right Front 35" 1/2
Left Rear 36"
Right Rear 35" 3/4
After:
Left Front 37" 1/2
Right Front 37" 1/4
Left Rear 37"
Right Rear 36" 3/4
#668
Like mentioned above, it's not a bad idea to install new sway bar links so that your sway bar stays horizontal. I went with JKS Quick Disconnects, which are adjustable and are easily disconnected (for more articulation off-road) by pulling a pin.
My remaining questioon is in regards to the rear. I am going from 17/57 to 19/60, rubicon shocks and i was thinking while i am under there i will thow in some 3/4 daystar comfort spacers. i see that the 1 3/4 budget boosts have a swaybar spacer for the rear. does the panel think that i will be fine with out a spacer or would i be better off putting a 3/4 spacer and some longer bolts in there
#669
#670
Ok this answers one on my questions on the front sway bar links How does a guy know what size to get?
