Lifetime maxcare warranty- calipers covered?
I have the Chrysler lifetime warranty on my 2012 Jku. I have what I think is a hanging caliper. I have manual trans. When I apply brakes, then release, it seems like a caliper is still applying pressure. Just enough to stop it from rolling when on a slight incline. I am fully capable of replacing the calipers myself. However, should I consider letting the dealer address the issue? I have a $100 deductible. Anyone know if calipers are covered?
Originally Posted by ronjenx
That question can be answered only by reading your warranty contract.
Have you narrowed it down to a particular brake?
jack it up and give your wheels a spin and see how freely or not they spin. There will always be some drag. If it is excessive pull the wheel and use brake cleaner and clean the heck out of the piston etc.
brake cleaner.
I still haven't addressed my hanging caliper issue. Yesterday I actually smelled some brake smell. When I got home I measured the temps of the wheels. Three were at 110 degrees and the right front was at 190 degrees. Looks like I found the culprit. I'm going to install new rotors and pads, clean and grease everything up good, then see if the problem goes away.
Ok, tackled the problem today. I was unable to free up the sticking caliper so I replace it with a new one. All brake related issues now resolved. Caliper was only $64, so even if it was covered by my warranty, I would have still done it myself to save the $100 deductible and to prevent a dealer mechanic from touching my Jeep.
The pins and boots can rust together too. They have kits at most shops for them. Mine was sticky... I found it was the boot had ripped and on of the pins was rusted so bad it would catch. Sounds like you found the problem though...
