Lift kit advice needed for newbie
Has anyone used this lift on a 2012 JKU? I'd like to run 33x12.5 BFG KM2's.
Rough Country Suspension 07-12 Jeep JK 2.5" Series II Kit w/ 2.2 Perf Shocks
You are going to get mixed reviews on this lift. I had a rough country lift on my previous jeep. It was alright, ride was a little stiff I ended up swapping it out for a Rubicon Express which I thought gave it a better ride and flex offroad, this was on a TJ. I am not sure how this particular lift handles on the Jk. The way I look at it is yes it will lift your jeep and you could even run 35s and it should work well off road but if you have the cash I would recommend getting a lift that uses extended brake lines and adjustable control arms. I am sure someone with this lift will chime in and give you some first hand knowledge. Good luck.
Thanks for the input, it's appreciated! JK is a DD and being on Long Island it will probably never see dirt. I would like it to ride nice and look tough. I have read alot of threads on here about lifts - JK has 3.21 gears, so more than 33's is prob not a good idea, which is ok.
If it may never see off road, maybe consider a spacer lift such as the teraflex budget boost. It will keep your stock coils ( and with shock extensions ) keep your stock shocks so the ride will feel the same.
Another newbie question: thinking about a lift for my 2012 Rubicon because I am getting 35" tires. May be a dumb question, but if I go for a full 4" lift will I be downgrading the stock equipment that I paid for in the Rubicon? I was thinking of just going with a 2.5" spacer lift, but really want to go for the 4" and understand that a lot more equipment will be replaced.
On a different note, how do you like your 35 inch pro comps? Which ones are you running?
I just did an aev 3.5" dualsport lift and i love it. Its a dd and family car. Looks and rides great. Its not the greatest lift for extreme wheelin but its suits my needs. I bought the procal module also. Put 35x12.50-18 km2's on it.
I had a teraflex 2.5BB on my previous JK WITH 33cooper STT's. in my opinion it was perfect, not to big for the 33's, but clearly lifted and drove exactly as stock. Just a note though, I had a rough country on before the teraflex and swapped it out as it was too stiff and rode horrible
