locker won't lock
Old Sep 1, 2013 | 01:02 PM
rickz's Avatar
Default locker won't lock
rear locker locked and wouldn't release got it free tried a few times and it finally worked , now rear won't lock front shows not locked light blinking but front is locked any ideas - not in warrenty 2007 rubicon
Old Sep 2, 2013 | 08:06 AM
pirate's Avatar
Pull your diff covers and inspect. Make sure the lock indicator plunger is not bent. Make sure the locker is actually locking , it's a common issue with stick rubi lockers failing, the magnetic lock fails, and it's not rebuildable. As well check the wiring/plug is all good on the diff.
How did you get your locker to unlock when it jammed on? Did it turn off by itself or did you pry inside of the diff?
Old Sep 2, 2013 | 03:54 PM
rickz's Avatar
I jacked up 1 wheel and turned wheel back and forth and it un locked messed with it today wiring good but it wont lock now the rear when tried the front it locks but the light keeps blinking but the front is locked i'm gonna take cover on rear off next weekend and inspect
