Lost the Airconditioning and heat ..
I was leaving gun range this morning and heat and AC wouldn't come on. I dunno what is wrong with it. Just reset computer and now I cannot get any buttons to light up on the front of the ac panel. I guess I will take off work and take it to dealership tomorrow. Any ideas... I can try tonight.
From the FSM:
NOTE: The blower motor is supplied with a 12V feed from the TIPM, through the blower motor resistor, whenever the ignition switch is in the RUN position. Due to an open circuit condition within the blower motor control switch the TIPM is UNABLE to detect an OPEN circuit for the blower motor.
Possible causes of an inoperative blower motor include:
Open fuse
Inoperative blower motor resistor
Inoperative blower motor switch
Inoperative blower motor circuit wiring or wire harness connectors
Open fuse
Must be blower motor. It been ticken for a while, but I really didn't think it was big deal. I don't have a blown fuse. Thanks again man. Guess I'll give them a call in the morning and drop it off.
Something like that heppened to the wifes 07 unlimited about 2 years ago.
As I was driving home from a store, I turned on the AC, and nothing, tried all the different settings and still nothing. Got home and tried to pull a code. Nothing. Let the JK sit for about 20 minutes, then started it up again. Still nothing. Pulled the negative cable and let sit for about 20 minutes. After re-installing the cable, started the JK up and tried the AC. Everything was normal. As I said, that happened about 2 years ago, and it hasn't happened since.
However, I can't find any evidence the HVAC blower motor is computer controlled. Looking at the wiring diagram, it appears the motor gets power directly from the fuse box (TIPM), and the rotary switch directs the ground through various combinations of resisters to control motor speed.
