Low Tire Sensor
Old Oct 11, 2013 | 02:12 PM
Razorbak's Avatar
Default Low Tire Sensor
I have a 2012 rubi that is 1 1/2 years old. A few days ago the low tire sensor came on. It does not state which tire is low. I went and check the air pressure and insured all had 32 psi in them. But the sensor did not go off. What is the issue?
Old Oct 11, 2013 | 02:16 PM
rob_engineer's Avatar
Definatly try a little higher pressure. I had been running around 32 psi. When colder weather came causing pressure to drop slightly and my light went on. Put in a couple more pounds and the light went off.
Old Oct 11, 2013 | 02:17 PM
ronjenx's Avatar
Does the sticker on your driver's door post say to have 38 psi in the tires?
Old Oct 11, 2013 | 02:34 PM
Razorbak's Avatar
I am running 285/75/17 Nitto terra grapplers if that makes a difference
Old Oct 11, 2013 | 02:44 PM
Ncb's Avatar
Ncb
Tire size doesn't matter. If the pressure drops below the PSI on the tire info placard you will get a light. With a programmer you can drop the threshold or zero it out.
Old Oct 11, 2013 | 02:46 PM
Razorbak's Avatar
That sensor never has come on before last winter. I will go put more air in it in the morning to see if that helps
Old Oct 15, 2013 | 09:06 AM
Razorbak's Avatar
Tool jeep in today and the sensor was bad. Repaired at dealership cost .
Old Oct 15, 2013 | 09:47 AM
Jiblet's Avatar
Was the warning light solid or flashing?
Solid means low pressure, flashing means bad sensor.
Old Oct 15, 2013 | 10:11 AM
Razorbak's Avatar
It flashed low tire then went off and the orange light stayed on. I didn't think the pressure was bad since all 4 tires were around the same psi
Old Oct 15, 2013 | 11:35 AM
Jersey_Devil's Avatar
If it happens again don't forget to check ur side tire too
Sent from my obama listening device
