LSD Question
Old Feb 8, 2007 | 06:45 AM
jeepn0811's Avatar
Default LSD Question
Does anyone know for sure what type of LSD the Jeep comes with. Is it a clutch type like the old one or gear like the Detroit TruTrac? Thanks.
Old Feb 8, 2007 | 08:43 AM
SpudRacer's Avatar
My Jeep comes with LSD?!? No wonder our radios blank out occasionally, and they can't see straight in the dark!!!
Now it all makes sense!!
Tom
Bryson City, NC
Old Feb 8, 2007 | 08:59 AM
HappyCurmudgeon's Avatar
Eternal ***erator
Spiders...
big
hairy
purple
Spiders!
what was the question?
Old Feb 8, 2007 | 02:41 PM
jeepn0811's Avatar
Sorry I didn't spell it out......LIMITED SLIP DIFFERENTIAL........ Wait, I'm sorry, the window sticker said Trac lok. Again I ask........does anyone know what type it is.
Old Feb 8, 2007 | 03:45 PM
nam6869usmc's Avatar
Clutch's,...Hope this helps you. Oh bye the way, I'm still l recovering from LSD = Vietnam was a great place at time's.
Clutch-type Limited Slip Differential
The clutch-type LSD is probably the most common version of the limited slip differential. This type of LSD has all of the same components as an open differential, but it adds a spring pack and a set of clutches. Some of these have a cone clutch that is just like the synchronizers in a manual transmission.
The spring pack pushes the side gears against the clutches, which are attached to the cage. Both side gears spin with the cage when both wheels are moving at the same speed, and the clutches aren't really needed -- the only time the clutches step in is when something happens to make one wheel spin faster than the other, as in a turn. The clutches fight this behavior, wanting both wheels to go the same speed. If one wheel wants to spin faster than the other, it must first overpower the clutch. The stiffness of the springs combined with the friction of the clutch determine how much torque it takes to overpower it.
Getting back to the situation in which one drive wheel is on the ice and the other one has good traction: With this limited slip differential, even though the wheel on the ice is not able to transmit much torque to the ground, the other wheel will still get the torque it needs to move. The torque supplied to the wheel not on the ice is equal to the amount of torque it takes to overpower the clutches. The result is that you can move forward, although still not with the full power of your car.
.[IMG][/IMG]
Old Feb 8, 2007 | 06:48 PM
jeepn0811's Avatar
Thanks for the responce and Semper Fi! I thought I read that it was like the TruTrac. Guess I was wrong. Oh well, for $295. it will work until the selectable lockers come out. I would have waited and ordered the Sahara with the Truloc, but like using it in 4 hi. Had ARB lockers on my LJ and they worked great in the mud and sand in 4 hi.
Old Feb 8, 2007 | 06:56 PM
biglynny's Avatar
Originally Posted by HappyCurmudgeon
Spiders...
big
hairy
purple
Spiders!
Mine came stock with windowpane
"Take this and quarter it" - Dennis Hopper in Easy Rider
Old Feb 9, 2007 | 12:54 AM
CHOPPER's Avatar
Windowpane...I haven't heard anyone refer to that in years...It brings back some great memories or should I say Flashbacks
Old Feb 9, 2007 | 03:52 AM
Eternal ***erator
*L* that's funny.
Old Feb 9, 2007 | 09:52 AM
mmccurdy's Avatar
I thought I had read that the JK uses a helical-gear type limited slip similar to the TJ's (as opposed to a clutch system), but I can't find reliable confirmation of that just now...
