Lubrication/Maintenance question
Old Jul 4, 2011 | 10:44 PM
Levi's Avatar
Default Lubrication/Maintenance question
Are there any grease fittings or parts that need lubricated or other maintenance issues that I need to keep an eye on that arent included in the maintenance schedule from chrysler?
Old Jul 5, 2011 | 04:45 AM
Mike Davis's Avatar
I have been tempted to use a needle grease gun device to inject grease into the ball joints. I, however, was reminded that it is a special "lifetime" grease and mixing types is not a good thing. Maybe trying to find that special grease would work even though you'd make a small injection hole in the rubber ball joint seal.
Old Jul 5, 2011 | 06:09 AM
Levi's Avatar
I'm a JK rookie, I appreciate all of the input I can get.
Old Jul 5, 2011 | 06:23 AM
archijeff's Avatar
A lot depends on the rigs activity. After a good day at the swamp I'll wash under carriage real good then break out a can of wd40 and spray the entire underbody (not soaking it, just a light spray)
Old Sep 21, 2011 | 07:51 AM
levosgien's Avatar
I'm struggling with what exactly needs to be greased.
1) Every oil change (bushings?) [Amsoil, Lucas Red n Tacky...]
2) After getting mud (all of the motor and undercarriage after a good wash?) [WD-40]
I haven't greased anything yet either after getting in the mud or as maintenance, help is appreciated.
Thanks.
