Manual Transmission - Is this normal?
Old Aug 2, 2008 | 12:35 PM
  #21
mikejwil's Avatar
Originally Posted by Offroadme
i have that annoying squeeeek when i shift 1 2nd and 3rd it's only when i shift into gear and it makes the sound for like a second then it stops. and it does not happen when i down shift. and i really don't want to take it to the dealer cause they are always morons. and they like to bust chops cause they have nothing better to do. i thought it was the heat shield rubbing on one of the brake lines under the hood but i bent the heat shield back a little and the noise is still there.
I will eventually sleeve the clutch hard line with split fuel line as others have done. That plastic line really looks vulnerable next to the sharp edges of the heat shield(s). I bent mine as well, just where it looked like it may rub.
Old Aug 2, 2008 | 03:44 PM
  #22
ibjeepr's Avatar
Default TSB locations
Ok, why can i not find the TSB's that everyone is mentioning about the tranny? I looked at the ProjectJK home page but didn't find then under the TSB section. Can someone tell me where to find these new TSB's? My clutch has always been extremely touchy shifty from 1st to 2nd (practically no friction zone) and now when i'm in neutral, no clutch, i'm hearing an odd, steady...I don't know....mechanical sound.
Old Aug 2, 2008 | 07:03 PM
  #23
mikejwil's Avatar
They're under "transmission tsb".... http://project-jk.com/jeep-jk/jeep-j...nsmission_tsb/
