Max trailer weight on an X
Old Sep 3, 2008 | 01:27 PM
obxjeep's Avatar
Default Max trailer weight on an X
I am looking at installing the Mopar hitch and wiring harness. I have a 4 door X, and I need to know what the max I could go on the trailer weight would be. The hitch says 3500# but I just want to make sure before I tear something up. Thanks!
Edit: I am looking at renting a uhaul trailer this weekend and its empty weight is 900 lbs. Would this be ok?
Old Sep 3, 2008 | 02:46 PM
deadspot's Avatar
What gearing do you have? This thread is a great reference - from the manual I believe... https://www.jk-forum.com/forums/stock-jk-tech-12/trailering-info-jk-sevice-manual-31646/
I believe if you have the 4dr and 4.10 gears you are good for 3500 (350lb tongue weight).
Old Sep 3, 2008 | 02:50 PM
steelerjeep's Avatar
Depends on the gearing that you have. I found out that mine can only tow 1000 lbs (little bit about that). Find out what gearing yours has and them check the owners manual.
Old Sep 3, 2008 | 07:47 PM
meljr's Avatar
I've pulled 5 to 6,000 lbs of utility trailer loaded with hardwood for several hundred miles with no problems. 08 Unlimited X with Mopar tow package, Auto, Limited Slip and 3.73 stock gears.
Old Sep 3, 2008 | 09:25 PM
jeeperjkj's Avatar
It might not've been a problem, but still probably wasn't the best thing to do. Had something happened you'd have probably been up a creek w/o a paddle and held liable for any damages since you were beyond the MFG recommended tow rating. Not worth it in my opinion.
Old Sep 4, 2008 | 02:12 AM
obxjeep's Avatar
Thanks for the input... I have the 3.21 gears (soon to be upgraded) and I found it in the manual. This forum is better than a manual anyday! Would it still be ok to pull a 900 lbs. trailer when the manual says max weight is 1000 lbs? Of course I probably will be at 1600-1700 when its loaded. Thanks!
Old Sep 4, 2008 | 02:36 AM
jeeperjkj's Avatar
I think it'll be tough on your gears, especially starting off from a dead start. Maybe try to park pointing downhill all the time...
You'll be much better off after a gear change.
Old Sep 4, 2008 | 11:33 AM
obxjeep's Avatar
So with everything said... is it the gears that limit the weight of the trailer? If that is the case then I think i'll be fine seeing since I have the 6-spd (i can handle not going into 6th). Am I reading everything correctly? Or is it something to do with the overall weight of the JK? (i.e. - I don't want the rear frame to bend/rear coils ruined or something of that nature) Thanks again!
Old Sep 4, 2008 | 12:06 PM
JeepinMass's Avatar
I didn't think uhaul rented trailers to convertibles.
Old Sep 4, 2008 | 04:55 PM
Frog Rubicon's Avatar
Same thing for me, my trailer is about 4500 lbs. If you have at least 3.73 gears, it's Okay.
