Metal chunks in differential oil
Old Jul 17, 2011 | 10:31 AM
single's Avatar
Had a very similar experience when draining my Tahoe diff. Come to find out, I had pulled the plug and went to get the oil to refill and one of my coworkers added the cuttings to the drain pan when I wasn't looking. Had me going for a little while.
Old Jul 17, 2011 | 11:30 AM
deathwagon's Avatar
Nice
When I was racing motorcycles, I was helping a buddy rebuild his FZR 400. While all of his parts were on the bench, I swapped out his left side engine cover with the one off of my YZF 600. They look almost identical, but have a different bolt pattern. I watched him try to figure it out for about 10 minutes before I handed his back to him. He repaid me later and the pranks escalated from there
Old Jul 17, 2011 | 02:12 PM
nthinuf's Avatar
Originally Posted by deathwagon
I busted out my little dental mirror and a flashlight and I don't see anything out of the ordinary. I'm going to chalk this problem up to an assembly mistake.
I would still consider going in to the dealership and showing them the pics/debris. See if you can get it documented 'just in case' there might be an issue in the future, and maybe even have them open it up and double check. (you did say that these are the stock gears, and not an aftermarket set, correct?)
Old Jul 17, 2011 | 03:30 PM
Yankee's Avatar
Originally Posted by ronjenx
MOPAR builds the axles? I always thought they came from an outside source, (Dana?), already built.
Your right of course, since they are Dana's. I still hold Chrysler responsible to check quality control of their multitude of suppliers.
Sure glad those shavings did not get into your gears OP!
Old Jul 17, 2011 | 03:44 PM
ronjenx's Avatar
Even if they do conduct quality inspections, they wouldn't inspect every one.
Dana should be doing that on the line as they come off the machine, or before parts go into the housing.
The magnetic plug saved the day, though.
Old Jul 17, 2011 | 03:50 PM
single's Avatar
I've always used Loctite 518 Gasket Eliminator. Been using it for 20 years. It works great. It doesn't start to set up until you eliminate the oxygen from it. You just have to make sure both surfaces are clean. Never had a leak yet (that I could blame on the sealant). I've used it in everything from differentials to final drives on 50,000 lb dozers.
Old Jul 17, 2011 | 04:18 PM
Wgrin's Avatar
Those are huge, look like links from a 7.62mm ammo belt.
Old Jul 17, 2011 | 05:17 PM
ronjenx's Avatar
A quick question, did your drain plug (at the bottom) have around 1/2" of (what appeared to be) wheel bearing grease? Mine did so I took it off and chose not to replace it. I'm guessing it's to keep metal off of the magnetic drain plug.
What appeared to wheel bearing grease on the magnetic drain plug was very fine metal grindings soaked with oil. Normal for the first drain, still normal thereafter, but to a lesser degree.
The magnetic drain plug's purpose is to attract steel, so they wouldn't put anything on it to prevent that.
Old Jul 27, 2011 | 05:20 AM
jhol111964's Avatar
Thanks guys. They're just the standard diffs as they came from the factory for an X model.
They do look like shavings from machining rather than the result of mechanical mayhem. Maybe my case didn't get cleaned after machining at the factory? I pulled the cover, and the gears look alright to my very untrained eye. No grind marks of any kind inside the case or on the inside of the cover.
A little video of the gears spinning:
http://s577.photobucket.com/albums/s...t=IMG_0485.mp4
On another note, do the JK diff covers normally have a gasket? Mine just had RTV sealant.
The wear on your ring looks ok. But those spider gears are getting pretty pointed. Check out the lower teeth on your passenger side carrier gear. I'm learning when it comes to JK's, but these were a weakness in the CJ's especially the oldest axles, particularly the fronts. Thanks for the photos.
Old Jul 27, 2011 | 06:11 AM
Mark Doiron's Avatar
Are you sure that wasn't just the typical metal "mud" (a mixture of gear oil and fine, metal shavings) from the gears? That's pretty typical. No, you don't use any special grease on the drain plug.
