Misfire on 07 stock 3.8
Old Nov 20, 2017 | 12:12 AM
  #21
TheTerminator's Avatar
Originally Posted by ronjenx
Anything that causes the crankshaft to slow when the computer expects to see it maintain or gain speed will throw a misfire code.
Without proper crankshaft reading the PCM can have trouble timing the TDC and igniting the mixture. So then you end up with misfires. Obviously changing anything but addressing the issue with crankshaft signal will give you zero results.
Old Nov 20, 2017 | 03:32 AM
  #22
ronjenx's Avatar
Yes, that is one item on the long list of items that can cause the crank to slow.
Old Nov 20, 2017 | 04:35 AM
  #23
Winyah's Avatar
Originally Posted by jtphoto JK
Misfire under load is usually a Bad sparkplug or plug wire. I suggest changing all the spark plugs and don't try and go fancy. The 3.8 likes the factory Champion platinum plugs. Anything else will likely cause you more grief... If factor original plug wires are still on there, change them as well.
I found the problem. Poor connection on the #6 wire at the distributor. I don't know why yet, as I resolved the issue on the way to work. Ill check later to see if corrosion or moisture. (all plugs, wires, distributor replaced 25000 miles ago at 130,000)
Thanks to all for the advice.
Old Nov 20, 2017 | 05:23 PM
  #24
It's awesome when the fix is so simple and free!
Old Dec 30, 2017 | 02:37 PM
  #25
Nostep's Avatar
Shaking engine to almost a stall when stopped in gear. 2007 JK. DTC misfire on cylinder #2. Checked with spark plug out of cylinder and in sight to watch for spark. Sure enough, no spark. Tried that wire and plug on another channel and it was working (therefore confirmed bad coil pack). Replaced for $50 . Fixed.
Old Mar 18, 2019 | 10:14 PM
  #26
Buchwild275's Avatar
I just had the same thing happen on my 2007 JK, misfire on #2 cylinder code. Tested the wire/plug and it was very weak. The plugs needed to be changed regardless so I replaced all of the plugs and wires with the factory parts. Cleared the codes and fired it up again and got the same results, rough idle and it threw the codes again about 30 seconds after starting. Replaced the coil pack, cleared the codes and it was good to go.
Old Sep 9, 2019 | 01:14 PM
  #27
Danny Brown's Avatar
Default My 2007 Rubicon is doing the same thing.
Originally Posted by Jkborow
Ronjenx I see you posted this check list many times on this site. Do you have insight into this problem. I'm tr ing to avoid tare down of my engine for a stumble at idle with a ce light. I could see the test procedure would prove vital for a random missfire.
But mine is isolated to #2 with all basic parameters in spec. This is a out of the ordinary issue. And that's why I'm asking for help. Trying to avoid hours of diagnosis.
My 2007 Rubicon is doing the same thing except mine is not firing out of the bottom 2 of the coil pack ,no fire at all . I’ve been trying to figure it out over a month now.
so far I’ve replaced the pcm,the coil pack 3 times plugs and wires the crank and cam positioning sensors and replaced the wires between the pcm and the coil pack still no fire on the bottom 2 prongs at the coil pack ,
you might check to be sure the prong directly across from the one that’s not firing and make sure it’s firing . Because the coil pack is actually 3 coils inside of the pack one coil runs 2 cylinders and the plug is 4 wires 3 coming from the pcm that control the coil and the brown /white one comes from the auto shutdown relay its the 5v trigger wire . I guess I’m going to have to take mine somewhere I can’t figure it out and nothing on these forums can tell me what is causing the bottom of the coil pack not to work .
Old Sep 10, 2019 | 06:33 PM
  #28
SoK66's Avatar
Just something to do a visual on. On my '09 The wire conduit Jeep used is crumbling. I've replaced as much as I can get to, but it's possible the stuff has fallen off and you have a wire to the coil pack that's shorting.
Old Nov 4, 2019 | 03:23 PM
  #29
hornetman's Avatar
Veteran: Navy
For Coil Pack, plugs and wires do you recommend OEM or something else? Just popped a P303 this morning on my way to work, music was cranking and I felt hesitation and louder noise from exhaust. 92K and last time I changed the plugs was about 40K miles ago. Still have stock wires and coil pack. I did replace wire lume about a month ago because of mostly crumbling heat/age deteriorating. Had my Jeep towed to house as I had the CEL & red lightening bolt and didn’t want to risk unknown damage. So going to add all new plugs, plug wires, & coil pack just need to know if I should get from local dealership.
Old Nov 5, 2019 | 04:02 AM
  #30
SoK66's Avatar
I'd stick with stock parts. You can source online at reasonable prices from outfits like Mopar Parts Giant, Mopar Parts Overstock, etc.
FWIW, the red lightning bolt suggests you have an issue with the electronic throttle., throttle body, etc. The harness connector at the throttle body is a POS and may have crumbled or popped off. You can get a new one with a splice kit, but pricey. Mine broke when I tried to reinstall it. Was able to source the connector and install it on the existing harness.
